Subject: No pointlight-atmospheric media interaction here. (43kb)
Date: 8 Oct 1999 20:08:11
Message: <37fe876b@news.povray.org>
So what am I doing wrong?
#include "textures.inc"
#include "stones.inc"
#include "metals.inc"
//global_settings { max_trace_level 12 }
//background {Black+Blue/5}
sphere {<0,400,0>,13
rotate<0,0,0>
pigment {White}
rotate<0,0,20>
pigment {White}
rotate<0,0,-20>
pigment {White}
rotate<0,0,40>
pigment {White}
rotate<0,0,-40>
pigment {White}
rotate<0,0,60>
pigment {White}
rotate<0,0,-60>
pigment {White}
rotate<0,0,80>
pigment {White}
rotate<0,0,-80>
pigment {White}
rotate<0,0,100>
pigment {White}
rotate<0,0,-100>
pigment {White}
#declare f=.084; // was 0.08
#declare R=399;
#declare funk=
isosurface { function
{noise3d(x*f,y*f,z*f)}
accuracy 0.01
threshold 0.0
bounded_by {
sphere{0,500*(.40+clock)}
rotate <0,0,90>
//pigment{functionabs((noise3d(x*2,y*4,z*4)*.875)&(noise3d(x*4,y*2,z*4)*.875)&(noise3d(x*4,y*4,z*2)*.875))
poly_wave}
pigment{Green}
finish{ambient 0.20 reflection .0}
normal {crackle}
//object {funk }
location <0,170,-400>*3.1
look_at <0,100,0>
angle 48
light_source{<0.005,0.00081,0.00081> color White*14
media_interaction on}
light_source { <0,0,0>
color White*14
spotlight
radius 90
falloff 89//28
tightness 1
point_at x
#declare j=10;
media { //media scattering
intervals 10
scattering { 2, red 0.05 blue 0.001 green 0.02}
samples 1, 10
confidence 0.9999
variance 1/1000
ratio 0.9
Download 'junk.jpg' (43 KB)
Preview of image 'junk.jpg'
Subject: Re: No pointlight-atmospheric media interaction here. (43kb)
Date: 8 Oct 1999 20:40:20
Message: <37FE8EE5.986C97BC@enst.fr>
> rotate<0,0,0>
> pigment {White}
> rotate<0,0,20>
> pigment {White}
> rotate<0,0,-20>
> pigment {White}
> rotate<0,0,40>
> pigment {White}
> rotate<0,0,-40>
> pigment {White}
> rotate<0,0,60>
> pigment {White}
> rotate<0,0,-60>
> pigment {White}
> rotate<0,0,80>
> pigment {White}
> rotate<0,0,-80>
> pigment {White}
> rotate<0,0,100>
> pigment {White}
> rotate<0,0,-100>
> pigment {White}
> #declare R=399;
> #declare funk=
> accuracy 0.01
> threshold 0.0
> bounded_by {
> rotate <0,0,90>
> poly_wave}
> pigment{Green}
> normal {crackle}
> //object {funk }
> camera {
> look_at <0,100,0>
> angle 48
> color White*14
> spotlight
> radius 90
> falloff 89//28
> tightness 1
> point_at x
> #declare j=10;
> intervals 10
> samples 1, 10
> confidence 0.9999
> variance 1/1000
> ratio 0.9
> [Image]
There is, but it doesn't appear because there's nothing to stop the
rays (except for the spheres, but the media here is white anyway).
If you add a plane { -z, -100 pigment { rgbt 1 } hollow } the media
appears...
Jerome
PS: if you render at higher res, you'll see the media appear for a few
pixels in the pic...
* Always listen to experts, * Jérôme M. BERGER
* they'll tell you what can't * mailto:ber### [at] iname com
* be done and why... * http://www.enst.fr/~jberger
* Then do it. *
Date: 8 Oct 1999 20:48:24
Message: <37FE90C9.A95DEA68@enst.fr>
Attached is a render with your parameters at 640x480. One of the sphere
has a blue pigment, one is red and one is green, the other are still
white but the media effect washes them out completely and all appear
white...
Jerome
PS: jpeg played havoc with most of the blue dots from the media but some
still remain to show it's here...
* Then do it. *
Download 'test.jpg' (45 KB)
Preview of image 'test.jpg'
Date: 8 Oct 1999 21:39:46
Message: <37FE9CD3.311984AD@enst.fr>
If you up the quality settings, you can make the media appear, but it
will cost you a lot of time... This one rendered at 10PPS on a PII 266
intervals 100
samples 10, 100
confidence 0.999999
variance 1/100000
ratio 0.9
Jerome
* Then do it. *
Download 'test.jpg' (14 KB)
Date: 9 Oct 1999 01:18:46
Message: <37fed036@news.povray.org>
grumble
GrimDude
gri### [at] netzero com
Date: 9 Oct 1999 10:20:03
Message: <37ff4f13@news.povray.org>
Thanks for the effort. What I eventually am trying to get is a "christmas bulb in
a wiffle ball in the fog," except my wiffle ball is an isosurface.
This whole effect renders quickly, is intuitively set up, and only requires a
White*14 intensity SPOTLIGHT.
When i go to POINTLIGHT, I have to put that plane in there and raise the intensity
several orders of magnitude to get it to work. And as you said, requires a long
render time.
What's the difference between spot & point lights??? Is this "intentional"??
> white...
> Jerome
> * Then do it. *
> [Image]
Date: 9 Oct 1999 15:21:48
Message: <37ff95cc@news.povray.org>
Greg M. Johnson <"gregj;-)56590"@aol.c;-)om> wrote in message > What's the
Spotlight works like a spotlight, er search light if you will. :)
Assuming, of course, that you define it properly.
If you are using Pov 4 Windows, just click on the area indicated in the
included image, while your Pov F.E. is up and running. ;)
GrimDude
Download 'Start.jpg' (2 KB)
Preview of image 'Start.jpg'
Date: 9 Oct 1999 18:36:33
Message: <37ffc371@news.povray.org>
Haha! I almost got a heart-attack there! Have I missed something, I thought.
;o)
Simen.
Date: 9 Oct 1999 20:54:05
Message: <37ffe3ad@news.povray.org>
heh
GrimDude
Date: 9 Oct 1999 23:20:22
Message: <380005f6@news.povray.org>
huh
Date: 11 Oct 1999 12:50:49
Message: <3802155A.C026CAAD@enst.fr>
> render time.
The difference is explained in the help with the "ratio" keyword. In
short, when you use a spotlight, PoV will divide the media into "lit"
and "unlit" areas and take more samples in the lit areas (with the
default settings, it will take almost no samples in the unlit area).
With the pointlight there is no "unlit" area and POV takes samples along
the whole ray. When you have an atmospheric media it means that a lot of
samples will be very far away and won't appear... Adding the plane cuts
the media in two (and therefore doubles the render time) wich forces
enough samples to be taken in front of the plane to make the media
appear (I've used a similar trick in my last irtc entry to make the mast
lamp visible: http://www.enst.fr/~jberger/images/jbhome.jpg )
Jerome
* Then do it. *
