Hej Jerome,
> Did you apply a pigment to the object (box/plane) you difference from
> the rest? If yes, try removing it, if not you'll just have to apply the
> csg to each component individually before texturing...
I didn't apply a texture to the object, but yes, applying the CSG to
each component before texturing finally solved the problem... (something
that might be worth while a comment in the online manual...)
Uwe.
