POV-Ray : Newsgroups : povray.binaries.images : Attempt at "Photo-Realism" Server Time
24 Nov 2026 16:06:20 EST (-0500)
  Attempt at "Photo-Realism" (Message 1 to 17 of 17)
Subject: Attempt at "Photo-Realism"
Date: 4 May 1999 11:38:18
Message: <372f065a.0@news.povray.org>
T-Storms and Tornadoes are keeping me from getting this done, but I
thought I'd risk my modem to share this with you all.
  Obviously, I don't have everything set exactly right yet, but radiosity is
really helping this scene. I cropped this down to the P51, so as not to
reveal too many details. I don't want to spoil everything! :)
GrimDude
vos### [at] arkansasnet
Download 'Rad51.jpg' (10 KB)
Preview of image 'Rad51.jpg'
Subject: Re: Attempt at "Photo-Realism"
Date: 4 May 1999 14:33:36
Message: <372F3038.606088FA@netvision.net.il>
Very good!
Just the cord that connects the back fin looks to grainy (or however it
is you may call it) as if it were not antialiased. Try rendering a
larger version perhaps!
Date: 4 May 1999 18:12:53
Message: <372F62FF.EC431841@iglou.com>
Just a little bit of a smoke trail and it would be awesome. Very very
nice as is.
> GrimDude
Date: 4 May 1999 18:54:23
Message: <372f6c8f.0@news.povray.org>
Very nice, but it doesn't really look like the propellers are moving.
Wow!  I actually critiqued an image!
-Ian
GrimDude <vos### [at] arkansasnet> wrote in message
news:372f065a.0@news.povray.org...
is
> GrimDude
Date: 4 May 1999 19:00:46
Message: <372F6E01.1FEC372C@aol.com>
I knew a kid when I was in 5th or 6th grade that drew these planes in
pencil incredibly well, nice 3D definition along with the shape and
details. Always has amazed me to this day. This plane looks very well too,
though I have no knowledge of these. Except to ask about the radio
wire(?). Doesn't it just go from the upright mast to the tail? Not all the
way from the cockpit? As far as the AA goes, using +AM2
(Sampling_Method=2), or a larger depth (+R4) with +AM1 at least, always
seems to net better results in my opinion when it comes to such fine
lines.
> GrimDude
 mailto://inversez@aol.com?Subject=PoV-News
Date: 4 May 1999 20:52:09
Message: <372f8829.0@news.povray.org>
Actually, the radio is on a tray behind the pilots seat (and armor). The
antennae wire, on period aircraft, runs up the armor plate to a standoff,
and then to a letoff wheel through the canopy. From there it proceeds to the
fin. The vertical mast is actually another radio, intended to be a
directional finder. Some radios, in different areas, used a radio of a
different frequency, which required a longer wire. In that case it was
sometimes run to a spring tensioner atop the d.f. mast. These days neither
would be used, in favor of a short six inch aerial, usually beneath the
fuselage.
  The wire is 1/32" in diameter, so despite the fact that I used +am2 +r1
(3x3 array), it doesn't show up very well even up close.
  I tried zooming in, per Lewis' request, but that changes the way the image
comes off. Don't ask me why. Radiosity is a mysterious critter indeed! So,
I'm back to working on the scene as originally outlined. Sorry, no further
hints yet. :)
  Thanks for the input! :)
GrimDude
Date: 4 May 1999 21:20:40
Message: <372F8E4F.DAE4F1C8@pacbell.net>
> fuselage.
The old xmtr/rcvrs they used needed that much wire and more if they wanted
any chance at all of picking up the signals at the low freq's they used.
Any idea what the actual length of the wire is from the set to end of wire ?
> GrimDude
Before I forget - Nice bird. I'm impressed - but not so much I wouldn't prefer
a larger more detailed image to ponder over  >-8 }
Ken Tyler
mailto://tylereng@pacbell.net
Date: 4 May 1999 21:53:05
Message: <372f9671.0@news.povray.org>
This is nice, I have been thinking about doing something with planes :)
how about banking the plane a little, and the prop needs work, maybe try
adding a near transparent disc to the prop as well to make the area where
the props spin look darker, may help to make it look more like motion.
is
> GrimDude
Date: 4 May 1999 22:46:48
Message: <372fa308.0@news.povray.org>
Ken wrote in message <372F8E4F.DAE4F1C8@pacbell.net>...
prefer
>Ken Tyler
  Somewhere around here I have the specifics, if you really want them
(specific to which model of the 51?) :)
  Double negatives are so confusing! Did you mean you really want another
image, or that you are not so impressed? :)
GrimDude
Date: 4 May 1999 22:51:54
Message: <372fa43a.0@news.povray.org>
Rick (Kitty5) wrote in message <372f9671.0@news.povray.org>...
>Rick
  Hmm, the disc is already there. Something about the way the scene is setup
has caused portions to disappear, and others to darken drastically. I could
*force* more density, but I think that, perhaps, the final image will make
things more apparent. This was just a beginning to radiosity with this
particular model (and scene), which is not without its own errors.
  Hopefully, more work and effort will pay off.
GrimDude
Date: 4 May 1999 23:09:37
Message: <372FA7D9.796E4F8E@pacbell.net>
Just curiosity. It is probably equivelant in length to a 1/4 wave antenna
just by guessing and no one else around here would care one way or another.
If it's in front of you drop the number off. If you have to rumage for it
don't waste your time. If I really want to know bad enough I could find
out in fairly short order on one of the ham groups.
> GrimDude
 I meant to say I like the model work from what I can see so far but the
image you posted was lacking in size, clarity, and sharpness. I would of
course prefer to evaluate anothers art using the best medium for that
evaluation and feel I have not yet had that advantage.
Ken Tyler
Subject: Re: Attempt at "Photo-Realism" 800x600 ~ 50k
Date: 5 May 1999 00:09:59
Message: <372fb687.0@news.povray.org>
heh, okay.
  14'-1/4" for the D-model Mustangs stationed in Europe. I understand they
were a little longer for the Pacific theatre. The frequencies in use at the
time are probably well known, but were not included in this reference
("Detail and Scale"; issue 8251, volume 51; Squadron Signal Publications,
1997). I could find out more, but the rest of my volumes are packed away too
deep. <G>
  Some of the problems I am seeing in the model I created are:
1) Close ports and seams seem to be swamped by ambient light. Check out the
bright radiator inlet, and rudder hinge line. Perhaps a problem with
distance_maximum?
2) I applied the decals (image_maps) only to the opposite side of the
aircraft, without clipping. Big mistake. I should remove them or do them
right.
3) The painted surfaces are darkening unrealistically, or so I feel. If
anyone has a clue as to why this is, let me in on it :)
4) The aircraft panel lines have been ignored by choice. The model has
already exceeded 8megs, and that's enough. If, I ever get things looking
good, I may go back and clip out the individual panels.
5) Wingtips are a b****. <G> Nuff said.
Further criticisms welcome.
GrimDude
Download 'Rad51-3.jpg' (47 KB)
Preview of image 'Rad51-3.jpg'
Date: 5 May 1999 03:53:15
Message: <372FEA53.E3AAABAC@pacbell.net>
GrimDude wrote:
>   heh, okay.
> deep. <G>
  Thanks for the input.
> distance_maximum?
  "distance_maximum?" ?
   Perhaps the amount of diffused finish used but more likely caused
 by phong highlighting in the metallic finish statement or a combination
 of the two. Remove the phong if it's in there and try specular instead.
 I like to try amounts starting with specular 0.6 roughness 0.001 to
 0.0001 for really tight highlights.
> right.
  Yup !
    How far is the light source from the object. I have noticed a more
 uniform lighting model when the light source is greater than say 200
 -300 pov units from the object. It seems to give more proximity related
 traits inside the 100-200 pov unit range and even more so from 100-0.
    Try different light source distances and evaluate the changes they
 make in the appearence of the model. Also try a silver colored fill
 light to add to the reflected color from the aircrafts surface.
 Couldn't hurt to experiment a bit at this point.
   Finish statements are of course always suspect when a texture, or
 pigment with finish, does not perform as expected.
  I'll fix the roof as soon as it stops raining. (cough)
  Tapered swept wingtips are a serious B**** !!! Nuff indeed.
I've had my say thank you.
> GrimDude
Ken Tyler
Date: 5 May 1999 03:57:29
Message: <372FEBD8.FCE03852@ica.uni-stuttgart.de>
> GrimDude
Very well done!
Marc
Marc Schimmler
Date: 5 May 1999 04:10:31
Message: <372feee7.0@news.povray.org>
GrimDude wrote in message <372f8829.0@news.povray.org>...
>directional finder.
Eek, poor edit again.
The vertical mast is actually *for* another radio,...
Sorry.
GrimDude
Date: 5 May 1999 04:30:47
Message: <372ff3a7.0@news.povray.org>
Ken wrote in message <372FEA53.E3AAABAC@pacbell.net>...
>GrimDude wrote:
>>   heh, okay.
>>   14'-1/4" for the D-model ...
No problem! Should you need any further information of this kind (relative
to the Mustang I, II, III, P51, P51A, B, C, D, K, H or F-82 Twin Mustang)
don't hesitate to ask!
>> Perhaps a problem with distance_maximum?
Well, I thought I had tried enough variations that I might have discovered a
bug somewhere. Still testing...
Actually, my texture is similar to your suggestion here. I used a high
brilliance, which I am testing now.
I was inside of 100 units with the light_source, but relative to what? My
model spans .1x.08x.03 (or so) units, and the light_source is 39 units
distance. I'm testing a much greater distance now.
Primitives are much easier to deal with then those sloping roofs.
  Additionally, I think there may be a bug in the program I used to convert
from TruSpace's .dxf output into Pov's smooth triangles. I'm looking into
this too, but I've noticed that the finish on the wing surface, and anywhere
I've done a sharp clip, has been dulled severely. I'm hoping it's just a
coincidence and I'll find something else that fixes this.
  The more I work on these planes (and no, not just 51's), the more I find
there is to add detail-wise.
Thanks for the suggestions! :)
GrimDude
Date: 5 May 1999 15:42:19
Message: <373086D2.84BB16B2@ndirect.co.uk>
I don't know much about planes, but I'm sure that the finished
article will be impressive.
Steve
> GrimDude
