With all of these fractals flying around, I decided to dig through a
book I had lying around. There's an interesting passage in the book,
where it is discussing these figures, called 3d dragon curves, and I
quote,
"..he uses IBM's computer resources to plot a million or more points in
three dimensions to generate a three-dimensional dragon curve. He then
runs a ray tracing program which determines the illumination of every
point and the positioning of it on a two-dimensional display. Needless
to say, this is beyond the capability of our personal compters."
The book is a little out of date, apparently.. (published in 1990) I
didn't quite use a million points, but I did use 1 out of every 5 of my
288000 calculated points. 57600 blobs still makes a pretty funky image,
tho..
-Alex V.
Download 'splash.jpg' (25 KB)
Download 'fount.jpg' (14 KB)
Download 'apple.jpg' (27 KB)
Preview of image 'splash.jpg'
Preview of image 'fount.jpg'
Preview of image 'apple.jpg'
Funky! Why is it called Dragon Fractals?
I guess you have serious problems to answer to the right posting! :-)
You can cancel the ones that have gone wrong with
EDIT -> cancel message in your netscape menu.
Have a nice day,
Marc
Marc Schimmler
The problem is that I only notice AFTER posting them!
> Have a nice day,
> Marc
> Marc Schimmler
That's what it is for!
To cancel your post after posting! After you've seen it is wrong!
Believe me, I had to do this too! ;-)
Marc
Marc Schimmler
Thanks! But what if someone tries to cancel my messages?
This is not possible! I would have been tempted to do that with -@--
posts! :-)
Only the poster can cancel it. And only from the same address if I
remember right.
Marc
Marc Schimmler
Yep, I have done many a Edit/Cancel Message in Netscape Communicator once
I notice errors after it posts. I just do the cancel soon as I can while
looking at the post.
> posts! :-)
> remember right.
> Marc
> Marc Schimmler
mailto:inv### [at] aol com?Subject=PoV-News
Hardly seems a fractal to me. Reminds me somewhat of 3D plotting using 2D
programs.
> quote,
> tho..
> -Alex V.
> [Image] [Image] [Image]
Animate them!!!
do them rolling round or something, that would look really weird, these are
excellent!
Alex Vandiver <van### [at] tiac net> wrote in message
news:37296E22.EE317082@tiac.net...
> quote,
> tho..
> -Alex V.
Marc Schimmler <sch### [at] ica uni-stuttgart de> writes:
> posts! :-)
> remember right.
Since you can fake your address, it is possible to cancel articles of
other users. I haven't tried it, but I know that it is possible at least
on other newsservers.
Thomas (hoping that Nick won't read this)
http://www.fmi.uni-konstanz.de/~willhalm
Are you sure about this? Administrators can delete messages, but
I would think that if I post a message here and go away, turn off
and come back tomorrow, I might not be able to remove even my own
messages. I'm on DHCP via my ISP, and tomorrow would probably
have a different unique identifier.
Just thinking.....
Steve
> > posts! :-)
> > remember right.
interesting images, what was the formulae, again?
(*hint*)
> quote,
> tho..
> -Alex V.
//Spider -- [ spi### [at] bahnhof se ]-[ http://www.bahnhof.se/~spider/ ]
And the meek'll inherit what they damn well please
Get ahead, go figure, go ahead and pull the trigger
Everything under the gun
--"Sisters Of Mercy" -- "Under The Gun"
I just press the delete key. Saves steps and works exactly the same.
Ken Tyler
mailto://tylereng@pacbell.net
anyone know how to delete your own messages in IE5?
Rygad
Marc Schimmler <sch### [at] ica uni-stuttgart de> wrote in message
news:37299B55.D1DB3ACF@ica.uni-stuttgart.de...
> Have a nice day,
> Marc
> Marc Schimmler
Umm, under "Compose" I think. Cancel message.
GrimDude
vos### [at] arkansas net
> (*hint*)
Unfortunatly, I'm not all that clear on the formula, myself, I just thought it looked
interesting.. ;>
Originally, I wrote the code to export the points in Turbo Pascal, but here's the POV
translation of it; make sense of it what you will. I'm not posting this as a real
macro, though, as it would take way too long to get any number of points. POV just
doesn't like the serious number crunching.. As soon as I can throw one together, I'll
post a .. *gasp* .. 2d .. image of the dragon curve, which will probably make it more
clear why it's called that.. Hrm. Actually, as posting of 2d images is unlawful
around
here, I just may have to TGAmosaic it.. *g*
-Alex
---- Code follows ----
-- Oooh! Indention! --
#declare detail = 400; // Lower numbers make more blobs..
#declare Qval = 0.97064; // Main parameter to change to get different shapes.
// Note that Qval=0 doesn't work.. this is actually the
// imaginary part of a complex number; P is the real
// part.
#declare R = seed(42);
blob {
#declare k = 3;
#while (k >= -3)
#debug concat(str(k,5,5),"\n")
#declare tx = 0.50001;
#declare ty = 0;
#declare magnitude = (k*k + Qval*Qval);
#declare Q = (-4*Qval/magnitude);
#declare P = (4*k/magnitude);
#declare i = 1;
#while (i <= 12000) // Iteration part. Each iteration is more accurate.
#declare temp_x = (tx*P - ty*Q);
#declare ty = (tx*Q + ty*P);
#declare temp_y = ty;
#declare tx = (1- temp_x);
#declare magnitude = sqrt(tx*tx + ty*ty);
#declare ty = sqrt((-tx+magnitude)/2);
#declare tx = sqrt((tx+magnitude)/2);
#if (temp_y < 0)
#declare tx = (-tx);
#if (rand(R) < 0.5) // 50-50 chance of using the negative square root
#declare ty = (-ty);
#declare tx = ((1-tx)/2);
#declare ty = (ty/2);
#declare tz = (P/2);
#if (mod(i,detail) = 0)
sphere {<tx,ty,tz>,0.0625,1 pigment {rgb vnormalize(<tx,ty,tz>)} finish {phong
1/(1+sqrt(tx*tx + ty*ty))}}
#declare i = (i+1);
#declare k = (k - 0.025);
Here's the promised 2d image. It uses the same function, but only takes a
crossection. If
you stretch your imagination, it *might* look like a dragon..
-Alex
Download '2ddrag.jpg' (45 KB)
Preview of image '2ddrag.jpg'
Interesting. Now I know almost nothing about fractals so I don't know if this has
anything to
do with it but the outline of this "dragon curve" looks a bit like the outline of a
julia
fractal. I've posted a julia fractal from Fractint.
crossection. If
> -Alex
> [Image]
Download 'fract001.gif' (82 KB)
Preview of image 'fract001.gif'
I think you might be on to something here!
I love Fractint, anybody else ever play with it?
Thomas Lake <tla### [at] home com> wrote in message
news:372B6AE8.C5B43480@home.com...
this has anything to
outline of a julia
a crossection. If
> > -Alex
> > [Image]
me
I thought everyone did...
Lance.
For the latest 3D Studio MAX plug-ins, images and much more, go to:
The Zone - http://come.to/the.zone
For a totally different experience, visit my Chroma Key Website:
Colorblind - http://listen.to/colorblind
Zillion times : I have a huge collection of standard fractals (made with
fractint) and personnal ones (in fractint you can write patches !)
Philippe
Rick (Kitty5) a écrit dans le message <372c48a0.1@news.povray.org>...
>Rick
>outline of a julia
takes
>a crossection. If
>> > -Alex
>> > [Image]
Yep, a hell of a lot.
> Rick
Now that I think about it, I bet that 90% of Fractint users are povers
as well.
I found an old copy on a shareware CD. . .YES YES YES! I'm a Fractint
addict!
-Ian
P.S. Are there any recent versions of it? If there is, where can I get it?
Thanks in advance.
Rick (Kitty5) <kit### [at] dial pipex com> wrote in message
news:372c48a0.1@news.povray.org...
> Rick
> outline of a julia
takes
> a crossection. If
> > > -Alex
> > > [Image]
19.6 AFAIK and that is an old version, search fractint on yahoo or whatever
search engine.
Philippe
Ian Burgmyer a écrit dans le message <372cbe71.0@news.povray.org>...
>addict!
>-Ian
>Thanks in advance.
>> Rick
if
>> outline of a julia
>takes
>> a crossection. If
>> > > -Alex
>> > > [Image]
hmm.. no, I can't really see a dragon in here... perhaps there is one, perhaps
not.. not in my eyes at least.
crossection. If
> -Alex
> [Image]
On Sun, 2 May 1999 17:13:35 -0400, "Ian Burgmyer"
>addict!
Try Spanky's page, the "www home of Fractint".
http://spanky.triumf.ca/www/fractint/fractint.html
Jerry Anning
clem "at" dhol "dot" com
Thanks a bunch! :)
-Ian
Jerry Anning <nos### [at] despam com> wrote in message
news:372cfbf8.31523386@news.povray.org...
> >addict!
it?
> Jerry Anning
Steve <sjl### [at] ndirect co uk> writes:
> Thomas
I'm almost sure. I have once accidentally made a massive crosspost.
Someone else was so kind to cancel it, because I didn't know how
to do this at that time. It basically results in faking the origin
and poster of the cancel request.
