This is a feasibility study NOT a finished pic. I wanted to see if it was
worth pursuing the idea
I would be grateful for your comments and advice before I continue.
Mick
This looks like its going to be tricky, but if you can pull
it off it will be one of the great pictures of the year... go
for it!
Mick Hazelgrove <mha### [at] mindaswinternetcouk> wrote in message
news:37276b06.0@news.povray.org...
> This is a feasibility study NOT a finished pic. I wanted to see if it was> worth pursuing the idea>> I would be grateful for your comments and advice before I continue.>> Mick>>>
How did you do the water? It looks like you replicated the same water
pattern at each level of the falls. If possible I'd suggest you make the
pattern at the edge of each fall different as well as the water pattern as
it falls from one level to the next.
Will you be putting any mist at the base of each fall? What about using the
dispersion and photon patch with the sun light source at an angle so that
you get a rainbow in each mist at the base of each fall? I was going to do
something like that but haven't taken the time yet ...
It's a good start. I eagerly await the final version.
Jim
Check out my web site http://www.kressworks.com/
It'll blow your mind (politically), stimulate your senses (artistically)
and provide scientific insights beyond compare!
Be sure to read the Warp maintained POV VFAQ:
http://iki.fi/warp/povVFAQ.html
Mick Hazelgrove wrote in message <37276b06.0@news.povray.org>...
>This is a feasibility study NOT a finished pic. I wanted to see if it was>worth pursuing the idea>>I would be grateful for your comments and advice before I continue.>>Mick>>>
The concept is definitely worth pursuing further. Is it one HF or two ?
Mick Hazelgrove wrote:
> > This is a feasibility study NOT a finished pic. I wanted to see if it was> worth pursuing the idea> > I would be grateful for your comments and advice before I continue.> > Mick> > [Image]
regards
Nathan O'Brien
no1### [at] no13net
http://www.no13.net
Thanks
Two but the final pic will have one per fall
Mick
Nathan O'Brien <no1### [at] no13net> wrote in message
news:372833AF.869F94F1@no13.net...
> The concept is definitely worth pursuing further. Is it one HF or two ?>> Mick Hazelgrove wrote:> >> > This is a feasibility study NOT a finished pic. I wanted to see if it
was
> > worth pursuing the idea> >> > I would be grateful for your comments and advice before I continue.> >> > Mick> >> > [Image]>> --> regards>> Nathan O'Brien> no1### [at] no13net> http://www.no13.net
It looks really good so far. The green water doesn't look right to me,
IMHO I would make it blue and clearer, if possible. Keep up the good
work.
Kyle
