POV-Ray : Newsgroups : povray.binaries.images : New TGAMosaic and a little dog Server Time
24 Nov 2026 16:36:21 EST (-0500)
  New TGAMosaic and a little dog (Message 1 to 20 of 20)
Subject: New TGAMosaic and a little dog
Date: 26 Apr 1999 18:02:13
Message: <3724D37E.80085F9E@uncc.edu>
I worked on my little utility TGAMosaic this weekend, following some
of Ken's suggestions (many thanks!). It now allows a little more
animation capability and reduces output file size considerably. A few
other changes have been thrown in as well. You can download the new
version at http://www.coe.uncc.edu/~adwoodfi/, or just see more samples.
    Here's a sample of the output, using one of my vicious beasts as a
model.
Andy
"There are three men in a boat with four cigarettes but no matches.
How do they smoke??"
  -The Riddler
Andrew Woodfin
UNC Charlotte Center for Precision Metrology
adw### [at] unccedu | http://www.coe.uncc.edu/~adwoodfi
Download 'priscilla.jpg' (59 KB)
Preview of image 'priscilla.jpg'
Subject: Re: New TGAMosaic and a little dog
Date: 27 Apr 1999 06:25:40
Message: <37258294.0@news.povray.org>
Andrew Woodfin wrote in message <3724D37E.80085F9E@uncc.edu>...
> model.
Nice. Can you do this with an image that says "Welcome" in yellow on a
black background?
Is it supposed to look like a rug?
>  -The Riddler
I give up. What is the answer?
Jon
Jon & Frances Berndt
email: jsb### [at] hal-pcorg, fan### [at] hal-pcorg
WWW: http://www.hal-pc.org/~jsb
League City, TX
Date: 27 Apr 1999 08:04:35
Message: <37259A6C.96D1C1@compuserve.com>
>>  -The Riddler
Hmm, use a lighter?
Date: 27 Apr 1999 12:02:46
Message: <3725D0C1.7B0A2D3D@uncc.edu>
I suppose it can look like a rug, but that's not really my intention.
Oh, and throw one cigarette overboard to make the boat a cigarette lighter.
Andy
> > model.
> black background?
> >  -The Riddler
> Jon
> League City, TX
  -The Riddler
Andrew Woodfin
Date: 27 Apr 1999 12:04:53
Message: <3725D214.A0BCF19F@ica.uni-stuttgart.de>
Arrrrrggggghhhhh! (Good one!)
Marc Schimmler
Date: 27 Apr 1999 13:51:25
Message: <3725EA36.79C4457@uncc.edu>
Like this?
Andy
> black background?
> Jon
> League City, TX
  -The Riddler
Andrew Woodfin
Download 'wel.jpg' (65 KB)
Preview of image 'wel.jpg'
Date: 27 Apr 1999 13:52:08
Message: <3725EA63.6983286E@uncc.edu>
Or this?
Andy
> black background?
> Jon
> League City, TX
  -The Riddler
Andrew Woodfin
Download 'wel2.jpg' (55 KB)
Preview of image 'wel2.jpg'
Date: 27 Apr 1999 14:55:15
Message: <3725F9E9.4DB40D9C@hal-pc.org>
Ha! Yes. I like this effect.
> Or this?
> Andy
> > black background?
Date: 28 Apr 1999 10:19:36
Message: <3727097D.3E41333@pacbell.net>
> model.
> Andy
  There seems to be a minor bug in the default output of your utility.
To get the image to "read right" that is to say to have it oriented
as expected using the default camera that is provided the input image
must be flipped or it is incorrect. The two examples below illustrate
what I am referring to. If I don't flip the image in a paint program
then the rendered image appears inverted on screen.
  Out of curiosity do you have an ini file or something set up so that
for your setup of pov it will use a right hand coordinate system
instead of Pov default left handed system. This might to some degree
explain the bassackwardness of the in vs out.
Ken Tyler
mailto://tylereng@pacbell.net
Download 'niceday.jpg' (19 KB) Download 'aniceday.jpg' (16 KB)
Preview of image 'niceday.jpg'
Preview of image 'aniceday.jpg'
Date: 28 Apr 1999 12:41:06
Message: <37272c12.0@news.povray.org>
I'd say this is because the image file is read from top to bottom. Top left
pixel of the image is in the bottom left of the TGA and BMP files.
Margus
Ken wrote in message <372### [at] pacbellnet>...
>Ken Tyler
Date: 28 Apr 1999 14:50:38
Message: <3727499B.FD41BA87@uncc.edu>
The short answer to Ken's question re: the coordinate system assumed by my
utility is no, it assumes left-handed standard POV.
    The long answer, also as a clarification of Magnus' remark, is this depends
on the software you use to create your TGA. I usually run mine through Lview
Pro to create the TGA, and this yields top-to-bottom ordering, with the first
pixel going to the top left corner. I've noticed the same "upside-downing" with
files created by some paint programs (e.g., PaintShop Pro), where the image
data is oriented so that the first pixel goes to the bottom left corner. I had
actually forgotten about this since I last encountered it, since all my images
are top-bottom. I don't work with a wide variety of paint programs, at least
not for creating TGA, so I don't know what is the most common pixel ordering,
but both are indeed equally valid under the TGA specification. I'll try working
a section into my code to discriminate between the different orderings so you
won't have to flip images before sending them through, this shouldn't be too
difficult.
    Just as a technical note: if you look at your 24-bit uncompressed (type 2)
TGA in a hex editor, the 18th byte will show the pixel ordering. Decimal 32
(hex 20) denotes first pixel goes to top-left corner, while decimal 0 denotes
first pixel goes to bottom-left corner. The TGA specification actually supports
the image origin being in any corner, and the original motivation behind this
escapes me at the moment.
Andy
> Margus
> >Ken Tyler
  -The Riddler
Andrew Woodfin
Date: 29 Apr 1999 01:07:30
Message: <3727db02.0@news.povray.org>
Not to sound super-demanding, but I must say that a LOT of people use Paint
Shop Pro, so you might want to consider changing it to that format.
This program looks cool, btw :)
-Ian
Andrew Woodfin <adw### [at] unccedu> wrote in message
news:3727499B.FD41BA87@uncc.edu...
by my
depends
Lview
first
with
had
images
least
ordering,
working
you
too
> difficult.
(type 2)
32
denotes
supports
this
> Andy
left
> > Margus
> > >Ken Tyler
>   -The Riddler
> Andrew Woodfin
Date: 29 Apr 1999 03:56:09
Message: <372802BA.D0A02CC1@geocities.com>
The standard behavior for TGA files is bottom-top (matches the standard cartesian
coordinates you learned in school). So, I'd say it was important to support those
TGA's.
Well, it should apply for all types (not just type 2). Also, you might mention
that byte is a bit-field. (does it have other toggles also?).
I believe that it had a lot to do with the physical memory layout of video cards
of the time, how it was addressed, etc. The format was created to support their
video cards, so that's where a lot of it comes from (especially that
'pseudo-color' or whatever mode). Also, do you have a copy of the official
Truvision specs for TGA?
Date: 29 Apr 1999 12:42:29
Message: <37287D13.2A264739@uncc.edu>
Jon A. Cruz wrote:
> ... Also, do you have a copy of the official
I do. I don't know if you're just curious or if you would like them. If the latter, I
can email them to you, they are in pdf converted from the original postscript.
Andy
  -The Riddler
Andrew Woodfin
Date: 30 Apr 1999 01:31:37
Message: <3729325D.485C53CF@geocities.com>
I
That's OK. I have some actual hard-copies laying around here somewhere (Truevision was
very nice about sending those out free of charge.)
I just wanted to make sure that you had them. Some of the people I've talked to on the
net were only using the simple descriptions out there, and not the real thing.
(BTW, for the lurkers and such out there who might need to know:
ftp://ftp.truevision.com/pub/TGA.File.Format.Spec )
Date: 30 Apr 1999 03:37:28
Message: <37294fa8.0@news.povray.org>
I know not everyone subscribes to the MS monopoly, but...
I recently bought MSWord on CD. It came with Photo Editor, and this outputs
tga's just right for this utility (TGAMosaic).
GrimDude
vos### [at] arkansasnet
Date: 30 Apr 1999 16:38:57
Message: <372A0602.439431BD@uncc.edu>
Martin Reddy's 2-D graphics file format page also has nice postscript versions of the
TGA
specification (since I'm not a rich text fan) at
 http://www.dcs.ed.ac.uk/~mxr/gfx/2d/Targa_tc.ps  (table of contents)
 http://www.dcs.ed.ac.uk/~mxr/gfx/2d/Targa.ps  (full TGA spec)
Andy
  -The Riddler
Andrew Woodfin
Date: 30 Apr 1999 16:41:20
Message: <372A068F.9964E72E@uncc.edu>
> -Ian
I fixed the problem in the code, so the utility now can read top-bottom or
bottom-top ordered TGA's and give the correct output. The revised version can be
retrieved from my webpage at
or in pov.binaries.utilities
Andy
  -The Riddler
Andrew Woodfin
Date: 1 May 1999 01:31:50
Message: <372A8325.A9572C9E@pacbell.net>
> Andy
Thank you Andy.
Ken Tyler
Date: 3 May 1999 16:06:24
Message: <372DF2E6.7E7BDC93@uncc.edu>
> Thank you Andy.
> Ken Tyler
 Anything for my favorite uncle.
Andy
  -The Riddler
Andrew Woodfin
