POV-Ray : Newsgroups : povray.binaries.images : Stupidity problem Server Time
4 May 2026 23:44:32 EDT (-0400)
  Stupidity problem (Message 1 to 10 of 15)
Subject: Stupidity problem
Date: 21 Apr 1999 01:23:17
Message: <371d52b5.0@news.povray.org>
Will someone please tell me why the following code renders as it does?
(place a camera at <0,0,-12>)
sphere{<0,0,0>,5 pigment{rgbf<0,0,1,.5>}}
sphere{<0,0,0>,2.5 translate -2.5*x pigment{rgbt<1,1,0,.5>}}
sphere{<0,0,0>,2.5 translate 2.5*x pigment{rgbt<1,1,0,.5>}}
gives me the image attached.  now; is it me, or, shouldn't the edges of the
small spheres meet perfectly with the edge of the big sphere?  I say this is
a stupidity problem simply because, well, it's obviously something simple
i'm not getting.
Mike Metheny
lon### [at] vtedu
mik### [at] loneshepherdcom
http://www.loneshepherd.com/
"When one's words are no better than silence, one should keep silent."
Download 'problem.jpg' (13 KB)
Preview of image 'problem.jpg'
Subject: Re: Stupidity problem
Date: 21 Apr 1999 02:03:05
Message: <371D5C4F.37C3D577@pacbell.net>
> i'm not getting.
> Mike Metheny
  You are correct in assuming the misconception on your part was the key
 player in this little drama. A sphere represented as:
 sphere { <0,0,0>, 1 = a sphere "2" units across !!!
    A sphere with a radius of 1 is 2 units across. The sphere object
 is defined by it's radius and not it's diameter. With this in mind
 you can see where your large sphere is 10 units wide ( 5*-x and 5*x)
 and each of the two 2.5 unit spheres are suffering the same fate.
 To have them kiss surfaces at the outside edge of the larger sphere
 your translate values should be 7.5 and not 2.5 as used above.
   Beware of the same trap with the box object. If you specify it
 as box { <-1,-1,-1>,<1,1,1> } you will have a box that is 2 units
 wide and not one unit like it might appear at a glance. Where the
 comma is between the two fields can be though of as your origin line.
 The illustrated example shows you are designating the objects walls
 at -1, +1 from that origin point. 1 + 1 = 3 : )
Ken Tyler
mailto://tylereng@pacbell.net
Date: 21 Apr 1999 02:52:08
Message: <371d6788.0@news.povray.org>
<< You are correct in assuming the misconception on your part was the key
Yes I understand this Ken.  But is not a sphere, sphere{<0,0,0>,5} centered
by default at the origin?  So, it extends, 5 units up, 5 down, 5 left, 5
right, 5 in, 5 out.  it is completely centered.  Thus; by making a sphere
radius 2.5 (diameter 5) by translating it by it's radius to the right, the
left edge should be at the origin, and the right edge should be at 5,0,0
correct?  In this image it does not appear that way.
Mike Metheny
lon### [at] vtedu
Date: 21 Apr 1999 03:08:04
Message: <371d6b44.0@news.povray.org>
It's a question of perspective.
With, the camera setup the way it is, you are looking through a small
portion of the sphere in order to see the intersecting edges.
GrimDude
vos### [at] arkansasnet
Date: 21 Apr 1999 03:35:47
Message: <371D7209.5E5A6DC9@pacbell.net>
I misunderstood the question. I thought that you wanted the two
smaller spheres outside the larger sphere, a set of three touching
in a line, which my explanation covered quite nicely thank you. As
Grim said if you can't see the forest through the trees remove the
forest for a better look. It appears you are getting shperical
aboration in the view of the interior of the larger sphere and
evaluations made this way will be invalid. It only takes a second
to comment out the larger sphere to see the two lesser spheres with
greater clarity.
Ken Tyler
Date: 21 Apr 1999 03:47:17
Message: <371d7475.0@news.povray.org>
Sorry Ken, but you got your maths wrong here.
The spheres are scaled and translated correctly to give the expected result.
Actually, they *do* give the correct and expected result!
I agree with GrimDude: It is a problem of perspective.
The camera is so close to the outer sphere, that the near part is
perspectively magnified so much, that it appears larger than the X/Y-plane
"equator" which lies farther back (and where the sphere really *do* meet at
the edges as expected.
I attached a screenshot from Moray where I recreated the scene and then
marked the actual equator with red and the *percieved* outer edge with
yellow (front, side, top and perspective view).
So long,
Johannes.
Download 'spheres.gif' (28 KB)
Preview of image 'spheres.gif'
Date: 21 Apr 1999 03:56:29
Message: <371D769B.BC1BE380@oc.chalmers.se>
Try to use the orthographic camera which would eliminate the perspective
problem. If I remember correctly I have had this problem myself. The
solution is no good if you want the perspective, but it is good to use
when placing things in relation to eachother.
/Johan
Date: 21 Apr 1999 04:02:14
Message: <371D783D.FFB08CD8@pacbell.net>
  My math was 100% correct for what I wanted it to do. It was
my understanding of the original question that is at fault here.
Ken Tyler
Date: 21 Apr 1999 04:18:17
Message: <371d7bb9.0@news.povray.org>
I was thinking of the set of solutions that satisfy a tangential line to the
point <-5,0,0> (assumed), but include the camera position. This set would be
null in that it cannot be satisfied from the current camera location, except
in orthographic projection (I think).
Perspective magnification, spherical aberration,....? Stymied...
Thanks for being agreeable. :)
GrimDude
Date: 21 Apr 1999 04:33:30
Message: <371d7f4a.0@news.povray.org>
>Ken Tyler
Yeah, the question wasn't very well put. Misleading in fact.
GrimDude
