POV-Ray : Newsgroups : povray.binaries.images : Povray phyics simulation Server Time
24 Nov 2026 17:02:21 EST (-0500)
  Povray phyics simulation (Message 1 to 14 of 14)
Subject: Povray phyics simulation
Date: 14 Apr 1999 14:37:29
Message: <3714D243.D52EF724@netvision.net.il>
I've rendered a better version for my lab report. Just thought it
*might* slightly interest someone out there.
I just want to point out that in my experiment, twisting the half-circle
lens 30 degrees would cause the light beam to bend 20 degrees. So I
tried it in the scene and it worked. The dark sphere is 0 degrees, and
every other sphere is 10 degrees more off.
Download 'physqqp.jpg' (41 KB)
Preview of image 'physqqp.jpg'
Subject: Re: Povray phyics simulation
Date: 14 Apr 1999 16:10:23
Message: <3714E7CD.8396A8DF@geocities.com>
This is really interesting.  Next year when I take AP physics I'll be
able put POV to practical use, Homework :-)
		Kyle
Date: 14 Apr 1999 16:23:57
Message: <3714EA71.3B43AD3D@Kopp.com>
Very cool.
-Nathan
Date: 14 Apr 1999 17:39:46
Message: <3714FD0F.EA63CE24@netvision.net.il>
Nathan Kopp wrote:
> Very cool.
Hey, it's all thanks to you!
Date: 14 Apr 1999 21:23:07
Message: <37153086.BC5751F7@iro.umontreal.ca>
Cool.
But make the beam red, so that it will look like a laser (thus, not
raising the question about color splitting).
Best,
    S.
Steven Pigeon                     Ph. D. Student.
University of Montreal.
pig### [at] iroumontrealca           Topics: data compression,
pig### [at] jspumontrealca          signal processing,
ste### [at] researchattcom           non stationnary signals
                                  and wavelets.
         http://www.iro.umontreal.ca/~pigeon
Date: 14 Apr 1999 22:36:51
Message: <3715419D.69976C7F@bahnhof.se>
looking good. Hmm, colour spectrum seems perfect :-)
//Spider
                "Marian"
        By: "Sisters Of Mercy"
Date: 15 Apr 1999 03:12:41
Message: <37158359.0@news.povray.org>
The light beam doesn t only "bend" of 20 degrees
but is also slightly reflected at 120 degrees ;)
-=Nicolas=-
Lewis <ble### [at] netvisionnetil> wrote in message
news:3714D243.D52EF724@netvision.net.il...
Date: 15 Apr 1999 11:27:14
Message: <3715F73A.91380EAA@netvision.net.il>
It's NOT a laser. The  cylinder on the left is a flash light, with a
piece of plastic blocking it. There is a thin, long, hole in the plastic
which allows a thin beam of *regular* light to go out.
Date: 15 Apr 1999 11:41:57
Message: <3715FAB4.F3644FD3@ica.uni-stuttgart.de>
But such a beam would break up into different colours after leaving the
prism. The standard POV can't simulate that. By using a monochromatic
light source such as a laser this wouldn't happen (and the output of POV
would be correct! :-) ).
Marc
Marc Schimmler
Date: 15 Apr 1999 11:52:13
Message: <3715FD16.7DC0ABAA@netvision.net.il>
I handed in the lab report today, but I would like to know how to
specify a spectrum for the light source (in UVPOV)
Date: 15 Apr 1999 12:22:49
Message: <37160431.4900E274@ica.uni-stuttgart.de>
I guess not in UVPOV. Have a look at:
http://www.newcolor.com/darenw/dswpov/dswpov.html
Marc
Marc Schimmler
Date: 15 Apr 1999 13:28:21
Message: <3716137f.3133167@news.povray.org>
On Thu, 15 Apr 1999 17:52:06 +0300, Lewis <ble### [at] netvisionnetil>
Here is a quote from a recent post by Nathan Kopp:
> I have implemented dispersion, but there's no default spectrum.  If you
> creat your light source like this:
> light_source
>   <10,10,10>
>   color <1,1,1> // this will be replaced, but the parser is a hack right
>                 //   now, so it is still required
>   color_map{    // here you define your light's spectrum
>                 //   this color_map acts like "average":  the first value is
>                 //   weight (intensity), the second is color
>     [1, <.5,0,0>]
>     [1, <.2,.2,0>]
>     [1, <.3,.3,0>]
>     [1, <0,.5,.5>]
>     [1, <0,0,.5>]
> Notice, the color map entries added up to <1,1,1>.  This spectrum will
> probably look bad (I made it up just now), but you get the idea.
Jerry Anning
clem "at" dhol "dot" com
Date: 15 Apr 1999 21:23:51
Message: <37168460.308B6702@home.com>
> > light_source
> >   <10,10,10>
> >     [1, <.5,0,0>]
> >     [1, <.2,.2,0>]
> >     [1, <.3,.3,0>]
> >     [1, <0,.5,.5>]
> >     [1, <0,0,.5>]
> Jerry Anning
Does this mean that UVPov can't actually simulate colour splitting. Instead you
have to fake it by defining the spectrum colours?
Date: 16 Apr 1999 01:25:22
Message: <3716BB94.6C499AB@aol.com>
Unfortunately, yes, I believe so. Same went for dispersion before it got
hard-coded into that custom compile of POV-Ray. You did the dispersion
about the same before then, by using texture averaging of the
refractions. Then POV-Ray code changed and it didn't work with 3.1
anymore until the dispersion patch.
> > > light_source
> > >   <10,10,10>
> > >     [1, <.5,0,0>]
> > >     [1, <.2,.2,0>]
> > >     [1, <.3,.3,0>]
> > >     [1, <0,.5,.5>]
> > >     [1, <0,0,.5>]
> > Jerry Anning
