here are some statistics.
This is the same scene, in different world resolutions(more data calculated in
some) and in the different output forms(checker and mesh)
I'll post the images in .jpeg(coming here)
Ran with povray 3.1e watcom compile.
p166MMx, overclocked to 200.
win 95, 64Mb RAM (win uses 32 of those)
The mesh is really only one object, but I've listed it as all the triangles.
If I use AA, the Black/White contrast of the boxes increase the tracing time a
bit(5-7 mins in the 50 grid.)(many sharp edges)
In general, the Boxes are far slower to render than the mesh. It's rather
frustrating, but then :-)
is there a difference if the boxes overlap?(a speed-difference)
I haven't tested for higher than 200x200, since it felt sooo slow, and I have
more fun things to do by the puter :-)
Stats for the 640x480 @AAoff renders:
If you think that the noise looks bad, well...
Size Output Objects Memory ParseTime(hms:s) TotTime(dhms:s)
50x50 Boxes 002 500 001 940 552 00h 00m 43s 043 00h 02m 59s 0179
50x50 Mesh 004 802 001 062 926 00h 01m 07s 067 00h 01m 50s 0110
75x75 Boxes* 005 625 004 277 176 00h 02m 11s 131 00h 07m 16s 0436
75x75 Mesh 010 952 002 157 166 00h 01m 39s 099 00h 02m 27s 0147
100x100 Boxes* 010 000 007 549 677 00h 02m 43s 163 00h 13m 16s 0769
100x100 Mesh 019 602 004 034 847 00h 02m 52s 172 00h 03m 40s 0220
150x150 Boxes 022 500 016 899 677 00h 06m 10s 370 00h 25m 57s 1557
150x150 Mesh 044 402 008 420 207 00h 06m 28s 388 00h 07m 19s 0439
200x200 Boxes 040 000 029 989 677 00h 11m 01s 661 00h 47m 39s 2859
200x200 Mesh 079 202 015 939 327 00h 12m 04s 724 00h 12m 57s 0777
* a slight difference in the box output code. no longer overlapping. (bug fix)
//Spider
[ spi### [at] bahnhofse ]-[ http://www.bahnhof.se/~spider/ ]
"Marian"
By: "Sisters Of Mercy"
