POV-Ray : Newsgroups : povray.binaries.images : Bug with Blobs ? Server Time
24 Nov 2026 17:54:30 EST (-0500)
  Bug with Blobs ? (Message 1 to 7 of 7)
Subject: Bug with Blobs ?
Date: 14 Mar 1999 05:51:34
Message: <36eb94b6.0@news.povray.org>
Hi There
If you look to the attached images there are many notches (look at the red
ovals) in the object which is a very simple blob made of spheres.
If I rotate the object, the notches change place and size, so I'm quite sure
it is a bug in POVRay (version 3.1a).
Any one knows about this ?
Philippe
Download 'Notches.jpg' (13 KB)
Preview of image 'Notches.jpg'
Subject: Re: Bug with Blobs ?
Date: 14 Mar 1999 06:44:13
Message: <36EBA0C6.654AEFE0@aol.com>
That does look peculiar. Did you try using the 'sturm' keyword in the
blob statement though?
But I haven't seen such a incomplete set of blobs before. In case you
haven't seen many of the recent animations using blobs, they don't have
any of this problem apparently. Nor have I ever seen them get as bad as
this. Trying to think from memory whether there was any fixes to blob{}
since 3.1a and only a texture placement fix comes to mind (I think).
Could that be it?
Ph Gibone wrote:
> Hi There
> Philippe
 mailto:inv### [at] aolcom?PoV
Date: 14 Mar 1999 13:33:17
Message: <36ec00ed.0@news.povray.org>
Bob Hughes a écrit dans le message <36EBA0C6.654AEFE0@aol.com>...
Yes !
>Could that be it?
I've tried several textures one very simple : texture{pigment {color
rgb<.8,.8,1>}}
Always the same
This image is one out of an animation set, an you can see the notches moving
and changing size just because the object is rotated !
Anyway here is the source :
#declare teta=texture{pigment {color rgb<.8,.8,1>}}
#declare tetb=texture{pigment{color rgb<1,.9,.9>} finish{reflection .95}}
#declare tetc=texture{pigment{color rgbf<1,1,1,1>}}
// create a smooth blobby shape
#declare Strengthval = 1 // (+ or -) strength of component's radiating
density
#declare radiuss = .45;
blob
  // threshold (0.0 < threshold <= StrengthVal) surface falloff threshold #
  threshold 0.61
     sphere {<0,.951057,0>, Strengthval, radiuss}
     sphere {<0,.425326,.850651> , Strengthval,radiuss}
     sphere {<.809017,.425326,.262866> , Strengthval,radiuss}
     sphere {<.5,.425326,-.688191> , Strengthval,radiuss}
     sphere {<-.5,.425326,-.688191> , Strengthval,radiuss}
     sphere {<-.809017,.425326,.262866> , Strengthval,radiuss}
     sphere {<0,-.951057,0> , Strengthval,radiuss}
     sphere {<0,-.425326,-.850651> , Strengthval,radiuss}
     sphere {<-.809017,-.425326,-.262866> , Strengthval,radiuss}
     sphere {<-.5,-.425326,.688191> , Strengthval,radiuss}
     sphere {<.5,-.425326,.688191> , Strengthval,radiuss}
     sphere {<.809017,-.425326,-.262866> , Strengthval,radiuss}
     sphere {<0,0,0>,Strengthval,radiuss/3 texture{teta}}
  sturm
  scale 2
  texture {tetb}
  rotate <clock, 2 * clock, 3*clock>
Thanks for taking time to answer
Philippe
Date: 14 Mar 1999 15:08:43
Message: <36EC15EA.279A2A95@aol.com>
I tried removing the internal bounding hierarchy, but that didn't seem
to help either.  One thing I did notice is that there is a lot of
components overlapping.  I'm still not sure if there's a bug being shown
or if they just aren't overlapping the way expected. Here's the scene
with the components visible:
camera {location <0, 0, -5>}
light_source {<10, 20, -30> color White}
#declare tetb=texture{pigment{color rgb<1,.9,.9>} //finish{reflection
.95}
//#declare tetc=texture{pigment{color rgbf<1,1,1,1>}}
density
blob
threshold #
  threshold 0.61
  //sturm
  scale 2
  texture {tetb}
  hierarchy off
union {
sphere {<0,.951057,0>, Strengthval}
     sphere {<0,.425326,.850651> , Strengthval}
     sphere {<.809017,.425326,.262866> , Strengthval}
     sphere {<.5,.425326,-.688191> , Strengthval}
     sphere {<-.5,.425326,-.688191> , Strengthval}
     sphere {<-.809017,.425326,.262866> , Strengthval}
     sphere {<0,-.951057,0> , Strengthval}
     sphere {<0,-.425326,-.850651> , Strengthval}
     sphere {<-.809017,-.425326,-.262866> , Strengthval}
     sphere {<-.5,-.425326,.688191> , Strengthval}
     sphere {<.5,-.425326,.688191> , Strengthval}
     sphere {<.809017,-.425326,-.262866> , Strengthval}
     sphere {<0,0,0>,Strengthval}
       pigment {color rgbt <1, 1, 1, .9>}
Date: 14 Mar 1999 17:09:12
Message: <36EC334D.D429DECF@aol.com>
It obviously is the last component (sphere) causing the problem. If
Strengthval is increased by multiplying it by 1.25 the artifacts more or
less disappear. The threshold, strength, radius adjusted in various ways
does not acheive the proper shape first made here without some pieces
missing.
So the interactions you need are disfunctional in that configuration for
some reason or another. May well be bug report material afterall.
But might not be an actual "bug" either and just the way blob works in
the current formulation.
Date: 14 Mar 1999 17:17:52
Message: <36ec3590.0@news.povray.org>
Mike a écrit dans le message <36EC15EA.279A2A95@aol.com>...
If you give the "visible" components a texture which is totally transparent,
the notches disapear ! But this is a very dirty and time consuming
workaround
Date: 14 Mar 1999 17:20:35
Message: <36ec3633.0@news.povray.org>
Bob Hughes a écrit dans le message <36EC334D.D429DECF@aol.com>...
>missing.
First remark : If you give the "visible" components a texture which is
totally transparent, the notches disapear ! But this is a very dirty and
time consuming workaround
Second remark : if you try with clock = 60 the notches are much bigger.
Third remark : the drawing you see is exactly what I want !
Hum... that's what I say to my clients.
Philippe
