A while ago GrimDude posted a nice improvement of
the two color pov icon. (The treat was called
"Pov Icon".)
Strongly inspired I made some icons myself all from
scratch though.
I've attached an iconlibrary with 3 icons.
One for the program (the one with a red frame),
one for .pov files (checkered floor with spheres),
and one for .inc files (only spheres).
I didn't make one for .ini files because
they are used by many other programs also.
The icons should work with only 16 colors, but they
look better with more.
Any comments?
P.S. The icons aren't Disney advertisings ;)
Rune S. Johansen
http://hjem.get2net.dk/rsj
Download 'povicons.icl.dat' (13 KB)
Wow! After that introduction I was looking forward to seeing your work! :)
Unfortunately, for some reason I don't have anyway to view them? :(
GrimDude
vos### [at] arkansas net
On Fri, 29 Jan 1999 14:58:48 +0100, "Rune S. Johansen"
>"Pov Icon".)
>scratch though.
Um...
How can one see the icons supposedly inside the .icl file?
Marc van den Dikkenberg
The PowerBasic Archives -- http://www.xs4all.nl/~excel/pb.html
All Basic Code Archives -- http://come.to/abcpackets
To view these one piece of shareware that will work is MicroAngelo, a set of
tools for creating, editing, and viewing icons. As to where to d-load, hey
you can search on HotBot or ask Ken as easy as I can :>
Mike Metheny
lon### [at] vt edu
http://loneshepherd.ml.org/
"When one's words are no better than silence, one should keep silent."
of
... or have a look at IconS: http://nmsf.sscc.ru/neuro/freeware.html
its just a little (Windows) freeware for extracting icons from all
kind of icon-holding file format.
Just my two rappen.
- Marco
Microangelo :
Version 2.1 (All time fav.) : http://floach.pimpin.net/utils/ma21.zip
And then the homepage : http://www.impactsoft.com
beat ya to it ;-)
//Spider
> Mike Metheny
> lon### [at] vt edu
GrimDude wrote in message <36b27548.0@news.povray.org>...
For Win95 users, right click on any desktop icon, select properties, then
hit the "change icon" button.
Eric
"Truth derives its strength not so much from itself
as from the brilliant contrast it makes with what is
only apparently true." --- Emanual Lasker
http://www.geocities.com/SiliconValley/Heights/2354/
Marc van den Dikkenberg wrote:
> Um...
Rename povicons.icl to povicons.dll, then change the icon as others
have described.
Avoids your having to go to needless expense for an icon editor,
especially when Microsoft has a perfectly good free icon editor
somewhere on their site -- search for "imagedit" and also "aniedit"
for their free animated cursor editor).
Bob & Kelly Crispen
cri### [at] hiwaay net
A polar bear is just a rectangular bear in a different coordinate system.
Thanks much for the lead, Bob, or Kelly.
> have described.
> Bob & Kelly Crispen
=Bob
Oops. I'm gonna have to remember to fix the sig on each message.
Btw, the expense for MicroAngelo or something similar is only
"needless" as I described it before if you only do icons once
in a blue moon like I do. As you may have discovered if you've
found the Microsoft editor -- I couldn't find it myself just
now, but I only spent a couple of minutes -- it's "basically
works but not that nice".
Bob Crispen
I finally got to thinking about this. LOL!
Just save the icl file to an appropriate directory, then right click on your
Pov shortcut, properties, change icon, Browse, and then locate the *.icl
file.
It will then allow you to choose any of the icons.
GrimDude
>"Pov Icon".)
>scratch though.
>Any comments?
>Rune S. Johansen
I like the floor-and-balls and use it for the SuperPatch. Here's my
DSWPov icon (attached). It;s a 64x64 pixels, in case you use large
icons (MS Plus!).
Peter
Download 'dswpov.ico.dat' (13 KB)
> file.
Yup. The only reason to name it from .icl to .dll is that, at least
in my build of Win95, it defaults to showing only .ico, .exe, and .dll
files ("Icon files"). It just saves a step.
Bob & Kelly Crispen
>>"Pov Icon".)
>>scratch though.
>>Any comments?
>>Rune S. Johansen
Thank you!
>Here's my DSWPov icon (attached).
>use large icons (MS Plus!).
>Regards,
>Peter
I think it is a very nice icon.
It's a little more original than mine :)
However, some parts of the icon is
transperant where it shouldn't be.
I guess you made the icon in a paint
program and saved as .bmp and then
changed it to .ico? At least the same
thing happens to me when I do so.
Rune S. Johansen
