POV-Ray : Newsgroups : povray.binaries.images : Cognac Glass Server Time
24 Nov 2026 17:54:25 EST (-0500)
  Cognac Glass (Message 1 to 19 of 19)
Subject: Cognac Glass
Date: 10 Mar 1999 13:09:52
Message: <36E6C207.4D987AFD@aol.com>
I'm having lots of fun with Nathan's new patch.  He and Ron should get a
kick out of this one (or anyone else who's read Jensen's papers).
There's a few artifacts that I think may be there because the glass is a
mesh. I'm still unsure of the brightness on the base, but I suspect it
may be that odd phenomenon of light getting brighter before the
fade_distance is reached.  Not sure though.
Took about 2 hours of fiddeling to come up with this, most of which was
learning how to use the patch - word to the wise: don't use photons on
infinite objects!
Render time was 38 minutes at 640x480 and AA 0.3.
-Mike
Download 'cognac.jpg' (40 KB)
Preview of image 'cognac.jpg'
Subject: Re: Cognac Glass
Date: 10 Mar 1999 13:22:45
Message: <36E6B872.922477AF@kolumbus.fi>
> infinite objects!
> -Mike
What a dashing image! Can the patch be gotten from somewhere now?
Juha Leppälä aka Jide
Date: 10 Mar 1999 13:31:19
Message: <36E6B967.A1DBBC54@pacbell.net>
Look for yesterdays announcement in povray.programming from Nathan Kopp.
Hey Mikey ! Good stuff. I have a similar project under way. Time
to start dusting off all of those old glass objects that never quite
made it into a scene because the caustics were wrong.. <g>
Ken Tyler
mailto://tylereng@pacbell.net
Date: 10 Mar 1999 13:47:04
Message: <36e6be28.0@news.povray.org>
Did I expect a glass image? Yes :) I'm doing a brandy glass, BTW.
The brightening of the light is something to investigate. Try this: make a
glass sphere with ior 1. A strange effect. Now do ior 1.1. The caustic seems
far too bright and sharp. I'll investigate this a bit more before I start
bugging Nathan...
Margus
Mike wrote in message <36E6C207.4D987AFD@aol.com>...
>infinite objects!
>-Mike
Date: 10 Mar 1999 14:44:33
Message: <36e6cba1.0@news.povray.org>
Is the foot of the glass flat? If so, what happens if you make it hollow?
Just an idea.
ingo
Met dank aan de muze met het glazen oog.
Date: 10 Mar 1999 18:18:51
Message: <36e6fddb.0@news.povray.org>
I love the caustics.
About the glass: it seems awfully thick (tough cognac glass
I suppose?); is that necessary to achieve the clearly
visible caustic effect, or does it work with thin refractive
objects as well?
Julius
Date: 10 Mar 1999 18:32:56
Message: <36E700F3.CF4492F6@Kopp.com>
I'm pretty sure I know why it is overly bright, but I'm not sure right now
exactly how to fix it.  Here's the problem:
     |______________|    glass
------------------------ ground
If the glass is just above the ground, photons will get deposited on
both surfaces.  But they are gathered independly from the scene geometry,
so you end up getting double the photons that you should get.  If you
set the "ignore_photons" flag in the glass, it shouldn't store photons
on the glass, so that should work as a workaround for now (speeds the
render time, too),
Sorry I didn't include any demo scenes.  Once you get a good shooting
density & gather density combination, you can usually just reuse that code
to get started with a new scene.
One way to get rid of artifacts is to increase the jitter amount.  If
that doesn't fix it, it probably is because your glass is a mesh.
Looks great, by the way!
-Nathan
> infinite objects!
> -Mike
Date: 10 Mar 1999 18:35:01
Message: <36E7016F.72E68084@Kopp.com>
what strange effect?
> bugging Nathan...
If it's too sharp, try a larger gather radius.  I've done all sorts of
tests with the brightness, so it _should_ be correct.
-Nathan
Date: 10 Mar 1999 20:15:56
Message: <36E717C6.7FE4B077@bahnhof.se>
now this is SOOOO great...
i have downloaded, three times.. (hmm, when NS says 502k of 270, something is
wrong) but not installed yet.. I'll get at it :-)
> infinite objects!
> -Mike
//Spider
( spi### [at] bahnhofse ) [ http://www.bahnhof.se/~spider/ ]
#declare life = rand(seed(42))*sqrt(-1);
Date: 10 Mar 1999 20:31:09
Message: <36E71AD9.C75418B2@ndirect.co.uk>
Rather NS than MS!
Steve
(as you can all see I've now got hold of the new browser version
settingw):
> > infinite objects!
> > -Mike
> >  [Image]
> //Spider
> ( spi### [at] bahnhofse ) [ http://www.bahnhof.se/+AH4-spider/ ]
Date: 10 Mar 1999 20:35:00
Message: <36E71C3F.63F059A3@bahnhof.se>
Steve wrote:
> Rather NS than MS!
agree!!
> Steve
> settingw):
congrats.
//Spider
Date: 11 Mar 1999 02:32:09
Message: <36E77E2D.482C759D@aol.com>
Thin will work.  I made the glass in Rhino because it makes smooth
curves and it fast to work with.  Making it thinner woulnd't be hard,
and the only reason I did the thickness is because I was going for
accuracy, which these caustics are!
Before this on I did a quick test with spatch using a thickness of one
patch and it looked great too.  That first test actually has neat
caustics because I had the light at a different distance.  I can't wait
to do an animation with a moving light, since the caustics change with
distance!
It's just too cool. :)
-Mike
> objects as well?
> Julius
Date: 11 Mar 1999 02:42:39
Message: <36E780A2.65A1DD95@aol.com>
Your diagram is right on.  I had a problem with coincident surfaces
(although I'm at a loss as to how I managed to model a mesh at exactly
y0), so I moved the plane down a little bit.  I'll mess with it some
more to see if I can get rid of it.
I really like how good this patch came out.  It's not really that slow
considering that half the time is spent rendering reflection and
refraction regardless of the photons.
The only problem I've run into is trying to render caustics from a plane
with a normal on it.  One thing that might be worth adding is a bounding
option to specify an area on infinite objects (or finite objects for
that matter) to shoot photons at.  That way instead of using the
object's bounding box, use one the user specifies.
I noticed that sometimes I would render once and then go to render again
and no photon gathering was done. Then it would only do it again if I
moved a light.  Are you caching the photon maps and reusing them?
-Mike
> render time, too),
Date: 11 Mar 1999 13:40:49
Message: <36e80e31.0@news.povray.org>
Steve schrieb in Nachricht +ADw-36E71AD9.C75418B2+AEA-ndirect.co.uk+AD4-...
+AD4-Rather NS than MS+ACE-
+AD4-
Why?
Rudy Velthuis
Date: 11 Mar 1999 16:23:28
Message: <36e83450.0@news.povray.org>
Nathan Kopp wrote in message <36E7016F.72E68084@Kopp.com>...
The rim of the shadow gets darker, but beyond that there is a thin brighter
"halo". Perhaps this is caused by total internal reflection or something?
Reflective caustics were turned off in the test.
I haven't looked, but I'm pretty sure I don't have a sphere with an ior of
1.1 around the house :)
So I can't test my claim. I said it _seems_ strange, but it's impossible to
visualise refractive caustics in one's mind, so maybe it's correct.
Changing the gather radius doesn't change it, btw.
Margus
Date: 11 Mar 1999 16:49:07
Message: <36E83A1B.177AE104@Kopp.com>
Ah, yes... that strange effect.  I should have warned you all (I'll document
it eventually).  That is caused by the way photon mapping works.  I haven't
found a good way to avoid it yet... increasing the density decreases the
dark/light ring.  That edge that you see is the border between using direct
lighting and using photon-mapped lighting.
-Nathan
Date: 11 Mar 1999 16:59:49
Message: <36E83C37.DE69FC6B@Kopp.com>
I agree.  I want to do this in such a way that it doesn't add too much
more to every object's struct (causing memory consumption to increase).
There is currently a workaround (but it's not very nice).  You take the
infinite object difference it and intersect it with a box that you want
to shoot photons at.  Put photon mapping on the intersection, then union
the two parts back together again.  Of course, if you do this with
complicated objects, rendering will be slower and memory usage will be
higher, so a better solution is something I'm looking into.
no caching going on now (I want to do it eventually).  Maybe it's an
initialization problem (like the problem with stopping a radiosity render).
I've never experienced it, but I will be on the look out for it.
-Nathan
Date: 11 Mar 1999 19:56:06
Message: <36E864C8.6EF2CCE@aol.com>
I noticed that you don't the more I worked with it (and I peeked at the
source hee hee).  I bet it is an initialization problem, especially if
you got some of those 'floating' globals like with radiosity and Daren's
dispersion patch.  It would probably be a good idea to create a
deinitialize_photon_code struct and then add that to the section that
executes the other other ones for lighting and radiosity whenever a
render is stopped.  I could probably handle something simple like that,
so if I find something I'll let you know.
I found a more serious problem when I was rendering an animation using
photon mapping.  It seems that the memory isn't being freed between
frames, so about 1/3 through it sucked my resources dry and I had to
reboot to get it back.  I noticed that you wrote your own code for
handling the memory allocation for the photon maps, so that probably
needs some tweaking so it releases it in all cases.
I'll probably post the animation somewhere soon.  It's of a goldfish
underwater, and it came out pretty cool, albiet short. :)
-Mike
Date: 12 Mar 1999 18:42:25
Message: <36E9A625.12F68F61@Kopp.com>
I hadn't yet run an animation test... apparantly there's another spot where
I need to deallocate memory.  I think I know where it is, now that I think
about it.  POV's code is not too well documented, so things like this are
pretty easy to miss.  Until I get it fixed, just render a few frames at a
time.  ;-)
-Nathan
> -Mike
