POV-Ray : Newsgroups : povray.binaries.images : Watch (out) again Server Time
26 Oct 2026 07:04:57 EDT (-0400)
  Watch (out) again (Message 1 to 5 of 5)
Subject: Watch (out) again
Date: 7 Mar 1999 20:50:14
Message: <36E32C2B.3EA47B60@aol.com>
I moved the dim fill-in lights and the dial isn't glowing anymore. It
also isn't white enough, but I'm taking a break from it now. Will post
it next to my web gallery page instead of continue to clutter up here
when I finish (ha! finish... funny).
Any comments might help me, and maybe not, thanks just the same.
 mailto:inv### [at] aolcom?PoV
Download '55ogpw.jpg' (39 KB)
Preview of image '55ogpw.jpg'
Subject: Re: Watch (out) again
Date: 8 Mar 1999 00:13:46
Message: <36e35c8a.0@news.povray.org>
Hey! Now this is looking good! :)
GrimDude
vos### [at] arkansasnet
Date: 9 Mar 1999 04:01:21
Message: <36E4E32B.B2C3AD64@aol.com>
Okay, got it re-done and uploaded to my web space:
 http://members.aol.com/iotadot/l12ogpw.jpg
   [theres a letter "L" then a number one in the files name, just in
case anyone attempts a re-write]
It now has the closest match, so far, to the actual coppery color I
mentioned before, and the dial is whiter too. Although, have to admit, I
haven't really looked at the real watch since I started this re-make).
Basically the same picture besides, used radiosity just to see how it
would go. Above all else the dial image_map needs to be much higher
resolution, there's a tendency to seem out of focus. It was a 300x300
image and it should probably be twice that.
>   http://members.aol.com/inversez/POVring.htm
Date: 13 Mar 1999 17:37:45
Message: <36eae8b9.0@news.povray.org>
Hi !
It's a nice one. But if I may make a few comments : I would decrease the
diffuse value of case of the watch. As apparently you've added a light shining
to the right of the watch, the back of it 'outshines'.
Besides, maybe the use of softs shadows would make this picture more
realistic.
Fabien Hénon
>    55ogpw.jpg    Type: JPEG Image (image/jpeg)
>              Encoding: base64
Date: 14 Mar 1999 07:00:16
Message: <36EBA471.DE5CA5D6@aol.com>
Actually the lights have remained nearly the same, I removed one very
dim one and lowered the brightness of the two main lights. Camera
location has moved slightly. But yes, I know what you mean. The edges
were too bright and I decided it was too much reflection doing it (the
back wall was fairly bright).
I've since added a mirror into the background and changed the "gold"
once again. I was going completely by memory instead of look at the
watch, kept in a drawer right now. Big mistake, it may seem coppery to
me whan I think of real golden coloring but it actually is not much
different than the typical gold ring a person wears. I went and ended up
with a copper tea kettle metal. Well, it will change again.
I did use area lights once, without jitter, problem is not enough shadow
falls onto anything much.
Thanks for the input. You can see the latest 2 images at the upper part
of this webpage:
 http://members.aol.com/iotadot/gallery1.htm
Fabien Hénon wrote:
> Hi !
> realistic.
> Fabien Hénon
