Ken wrote:
> > Here is an index to 100 superellipsoid shapes.
I've once used a superellipsoid (man, this types real hard)
to model the front of a Sony DAT recorder. I realized it
was slow as hell, so I made a quick macro for rounded boxex
using boxes and cylinders and spheres. Renders a lot faster.
So I'ld suggest using unions of boxes, cylinders and spheres
if you just want the range of superellis you "indexed".
2ct
Markus
Ich nicht eine Sekunde!!!" H. Heinol in Val Thorens
Markus Becker wrote:
> > Ken wrote:> >> > Here is an index to 100 superellipsoid shapes.> > I've once used a superellipsoid (man, this types real hard)> to model the front of a Sony DAT recorder. I realized it> was slow as hell, so I made a quick macro for rounded boxex> using boxes and cylinders and spheres. Renders a lot faster.> > So I'ld suggest using unions of boxes, cylinders and spheres> if you just want the range of superellis you "indexed".> > 2ct> > Markus> --> Ich nicht eine Sekunde!!!" H. Heinol in Val Thorens
I think you would be surprised at how fast these rendered. I had
AA turned on and rendered the 640x480 image in under 6 minutes
on my p-200.
Ken Tyler
tyl### [at] pacbellnet
Ken wrote:
> > I think you would be surprised at how fast these rendered. I had> AA turned on and rendered the 640x480 image in under 6 minutes> on my p-200.
This sounds reasonable. But what I was doing was cutting lots
and lots of little holes into it, filling them with knobs
and whatnot. And it got slower and slower. As I switched to
the unioned box/cylinders/spheres it rendered at least 3
times faster (at least the part which contained the round box).
Markus
