Spider wrote:
> Oooops...
> I forgot to say that I really like the idea, and it is a good job so far...
> It _is_ a good job..
> I haven't yet read the books... maybe I should...
You should, definitely...
Markus
"Denkst Du vielleicht über den nächsten Satz nach, den Du sagen willst?
Ich nicht eine Sekunde!!!" H. Heinol in Val Thorens
In article <36983FA2.7E305562@inlink.com>, nhp### [at] inlink com says...
> Here is the Ringworld built closely to scale. The dimensions state that
> the ring if layed flat is 600 millin miles lon and is 1 million miles
> wide. Sooo..... the Radius of the circle is 191.083 units with a width
> of one unit.
Actually, Niven states that the radius of the RingWorld system is
93 million miles (giving it an Earth orbit and similar global climate).
This gives you a circumference of ~585 million miles, which is close to
your figure. The ring is a million miles wide, with walls that reach up
1,000 miles toward the sun on each edge of the ring. The thickness of
the "floor" and walls of the ring are about 1 kilometer, making seas look
like bumps and mountains like sharp dents if you looked at the ring from
the outside.
Great inspiration for yet another POV project, I haven't thought
of the RingWorld in years!
Rich Allen
