POV-Ray : Newsgroups : povray.binaries.images : Saturday night doodle. - Buddha01c1_.jpg (0/1) Server Time
29 Nov 2026 05:27:04 EST (-0500)
  Saturday night doodle. - Buddha01c1_.jpg (0/1) (Message 1 to 50 of 97)
Goto Latest 50 Messages Next 47 Messages >>>
Subject: Saturday night doodle. - Buddha01c1_.jpg (0/1)
Date: 18 Oct 2008 17:06:22
Message: <2sjkf4hbpn9fm3g89asc64q8g6o5u6oqpp@4ax.com>
Just a doodle while thinking about changing an avatar.
 Does anyone have any suggestions or comments?
Regards
Subject: Saturday night doodle. - Buddha01c1_.jpg (1/1)
Date: 18 Oct 2008 17:06:28
Message: <eujkf49ophafs4r620i7k2dtqieaqcodlh@4ax.com>
Download 'Buddha01c1_.jpg' (100 KB)
Preview of image 'Buddha01c1_.jpg'
Subject: Re: Saturday night doodle. - Buddha01c1_.jpg (1/1)
Date: 19 Oct 2008 03:06:06
Message: <48fadc5e$1@news.povray.org>
Hmm... Difficult to say... I like the concept in itself. It has a rather
strong yin-yang content. What I find disturbing though, are the sharp
boundaries between states (night/day; black/white). In a boudhistic sense
(not that I know much about boudhism) I would expect smoother transitions
and a sense of revolution (the wheel) more pronounced...
Date: 19 Oct 2008 03:29:22
Message: <7eolf4l6pls9ssoer96mcfgrsl00cr1mki@4ax.com>
On Sun, 19 Oct 2008 09:06:07 +0200, "Thomas de Groot" <t.d### [at] internlDOTnet>
Thanks Thomas,
	I think that too, that there should be a merge between the day and night
sky but how to reflect that in the ground? I think that I will try a repeating
image map texture on the plane. With the image map split into night/day/night.
Regards
Subject: Re: Saturday night doodle. - Buddha01c1_.jpg (0/1)
Date: 19 Oct 2008 06:18:58
Message: <48fb0992$1@news.povray.org>
  It *is* allowed to put your question and the image in the same post.
Date: 19 Oct 2008 06:32:27
Message: <853mf4ljqvnn01i8fjggkijvpb5raq700n@4ax.com>
Thank you but I wish someone would tell my updated news reader that ;)
Why do s/w houses fix what's not broke? $?$?$?$?$
I feel a rant coming on. Anyway the next image will see if it works.
Regards
Date: 19 Oct 2008 07:28:49
Message: <48fb19f1@news.povray.org>
  Your news reader doesn't allow you to embed an attachment to the post
you are making? What does it do if you want to embed more than one
attachment (not even a rare occurrence in this newsgroup, as often
people will attach two or more images to the same post)? If you want to
attach 10 small images to your post, will it create 10 different
threads? That would be horrendous.
  Perhaps a change to a better news reader could be in place, then.
Date: 19 Oct 2008 07:56:35
Message: <928mf4tp2rsddbrq5p49qhlvgh81l16v7a@4ax.com>
It does but the default setting is to split attachments into sections. I thought
that I had configured it correctly but obviously not :(
When I bought this laptop I could not transfer the old messages (OT mostly) to
the new Free Agent so I bought the full version, (how much money do we spend to
run a piece of free software?) and it has more settings and features than you
can shake a stick at. I've changed the default settings now and later will try
to post a couple of images together. If they are worth posting.
Regards
Date: 19 Oct 2008 12:44:45
Message: <48fb63fd$1@news.povray.org>
> Thanks Thomas,
You might try a 'splicing' border with fragments of the images
interleaved to produce the transition.
Or...rather than a graded transition, just some sort of framing.  I
think the blunt edges abutted is part of the problem.
Date: 19 Oct 2008 15:32:48
Message: <jq2nf4pdd2m4rk955u5dhhfntirb2r8cbg@4ax.com>
I'm not too sure what you mean, Jim.
I'm working on the sky first, rewriting the code for the stars. {I'm using a
modeller and having 3000 stars as 3000 objects was slowing it down a bit. (Beta
testing and you have to push the limits :)} After getting the day sky to blend
in with the night sky I'll look at the plane.
So how would I splice the images on the floor? I'm thinking along the lines of
your mosaic table and can't imagine how it could be done.
The framing is a good idea as well especially since the North - South faces
don't match up.
Regards
Date: 20 Oct 2008 13:24:09
Message: <48fcbeb9$1@news.povray.org>
"Stephen" <mcavoysAT@aolDOTcom> wrote in message
news:eujkf49ophafs4r620i7k2dtqieaqcodlh@4ax.com...
  I tried to reply to your post last night Stephen, but for whatever reason,
my newsreader, (OE), just wouldn't connect to the povray server. This isn't
new, every Sunday night, I can't connect for some reason. It seems to be
doing this for around 2 to 3 hours at a time. Anyone else getting this using
a newsreader? (The main website groups show ok).
  Anyway, what I wanted to ask is where do you get that buddha model from? I
want to have a play...  ;)
  I agree that there should be some kind of 'fade-in/fade-out' tranquility
in your image somewhere. I think that would make it with the concept you
have, (which I like).
     ~Steve~
Date: 20 Oct 2008 16:21:21
Message: <c1qpf45ih4fjo7g2oncj3rcngfpgddba9q@4ax.com>
Just a quick reply before going for something to eat. (I've just driven up to
Glasgow)
I found the Buddha at
http://www.3dvia.com/
You will have to register and search for Budda.
Regards
Date: 20 Oct 2008 18:02:04
Message: <hhvpf4pj6ndkfonqp242djs1dhd14hp9v2@4ax.com>
I sometimes have that problem as well :(
I'm working on it but have some slight problems, then I will work on the floor.
It is just a diversion from the my Tina Chep animation and I don't want to spend
too much time on it.
Regards
Date: 21 Oct 2008 03:33:48
Message: <48fd85dc$1@news.povray.org>
"St." <dot### [at] dotcom> schreef in bericht news:48fcbeb9$1@news.povray.org...
> reason, my newsreader, (OE), just wouldn't connect to the povray server.
> This isn't new, every Sunday night, I can't connect for some reason. It
> seems to be doing this for around 2 to 3 hours at a time. Anyone else
> getting this using a newsreader? (The main website groups show ok).
Yes, happens once in a while, whatever the day or the hour by the way.
Date: 21 Oct 2008 05:21:42
Message: <48fd9f26$1@news.povray.org>
news:c1qpf45ih4fjo7g2oncj3rcngfpgddba9q@4ax.com...
>> I
> to
> Glasgow)
     Ah, ok, thanks. You drove up to Glasgow??  0.0
       ~Steve~
> Regards
>     Stephen
Date: 21 Oct 2008 05:47:47
Message: <48fda543@news.povray.org>
"Thomas de Groot" <t.d### [at] internlDOTnet> wrote in message
news:48fd85dc$1@news.povray.org...
     Hmm, well at least it's not just me. One of life's mysteries, Thomas!
       ~Steve~
> Thomas
Date: 21 Oct 2008 12:13:02
Message: <5qvrf4dp61ktd224nqq1gleutaf8851jrf@4ax.com>
On Tue, 21 Oct 2008 10:21:04 +0100, "St." <dot### [at] dotcom> wrote:
>     Ah, ok, thanks.
My pleasure ;)
And I'm driving back to London Thursday evening :(
8 hrs listening to R4 :)
Regards
Date: 21 Oct 2008 12:37:47
Message: <48fe055b$1@news.povray.org>
news:5qvrf4dp61ktd224nqq1gleutaf8851jrf@4ax.com...
>>     Ah, ok, thanks.
> My pleasure ;)
     Phew! I don't envy you my friend.
    LOL!!  Don't fall asleep. :o)
        ~Steve~
> Regards
>     Stephen
Date: 21 Oct 2008 13:00:10
Message: <of2sf45jpmt9g2ch42jtg49bbl0e9r79g7@4ax.com>
>>>     Ah, ok, thanks.
>> My pleasure ;)
I prefer it to flying and I've hired a good car.
I can always switch to Handel's Concerto Grosso :)
Regards
Subject: Re: Saturday night doodle. - Buddha01c1_.jpg (1/1) - Buddha03c2_0000.jpg
Date: 22 Oct 2008 05:39:35
Message: <d4ttf4lv3r8c6g4pu5kcv17guu773nmtc2@4ax.com>
On Sat, 18 Oct 2008 22:06:22 +0100, Stephen <mcavoysAT@aolDOTcom> wrote:
I've managed to create a fade but it looks a bit cylindrical to my eyes. The
floor still needs a bit of work.
Regards
Download 'Buddha03c2_0000.jpg' (60 KB)
Preview of image 'Buddha03c2_0000.jpg'
Date: 22 Oct 2008 10:56:52
Message: <48ff3f34@news.povray.org>
"Stephen" <mcavoysAT@aolDOTcom> schreef in bericht
news:d4ttf4lv3r8c6g4pu5kcv17guu773nmtc2@4ax.com...
> The
Better!
Could you do a fade that would take up, say, 1/4 of each image?
> The
Better!
> The
Better!
> The
Better!
> The
Better!
> The
Better!
Subject: Re: Saturday night doodle. - Buddha01c1_.jpg (1/1) - Buddha03c2_0000.jpg - Buddha03c5_.jpg
Date: 22 Oct 2008 21:34:03
Message: <g2lvf45guv6d9tqfaareesf0nsf2j9devv@4ax.com>
Download 'Buddha03c2_0000.jpg' (1 KB) Download 'Buddha03c5_.jpg' (310 KB)
Preview of image 'Buddha03c5_.jpg'
Date: 22 Oct 2008 22:12:59
Message: <48ffddab@news.povray.org>
The green status looks much more 3D to me than the gold one in this
setting. The scene really looks kind of ... flat, overall.
Date: 23 Oct 2008 03:25:10
Message: <490026d6$1@news.povray.org>
news:g2lvf45guv6d9tqfaareesf0nsf2j9devv@4ax.com...
> On Wed, 22 Oct 2008 16:56:51 +0200, "Thomas de Groot"
> That was more difficult than I thought it would be. My maths gland has
> gone on
> strike + a problem with Beta 29 and me trying to be clever with r.g.b
> values in
> reflections.
Bravo! as far as the ground is concerned, that looks much better. Could you
do the same for the background?
Date: 23 Oct 2008 05:01:59
Message: <1cf0g49lsblc93fg5l0vfk7crl8n4cqk9k@4ax.com>
Subject: Re: Saturday night doodle. - Buddha01c1_.jpg (1/1) - Buddha03c2_0000.jpg - Buddha03c5_.jpg - Buddha03d2_.jpg
Date: 23 Oct 2008 05:25:54
Message: <8og0g4l726spv0mdl59nmcg4esj0rfbg92@4ax.com>
Download 'Buddha03c5_.jpg' (1 KB) Download 'Buddha03d2_.jpg' (78 KB)
Preview of image 'Buddha03d2_.jpg'
Date: 24 Oct 2008 03:27:07
Message: <490178cb$1@news.povray.org>
news:8og0g4l726spv0mdl59nmcg4esj0rfbg92@4ax.com...
> On Thu, 23 Oct 2008 09:25:12 +0200, "Thomas de Groot"
>>you
> Yes Sir :-)
hmm hmm hmm.... Still a little boundary line visible on the day side, but
that's the idea indeed!!
Date: 24 Oct 2008 05:23:50
Message: <2153g4t4jodecpqvnhhrvdm957loktvnu2@4ax.com>
Date: 1 Nov 2008 01:46:17
Message: <490bed29@news.povray.org>
> don't match up.
Sorry I never got back to this, finally forced myself to take a break
from work and relax a bit.  I guess I didn't describe what I meant very
well.
Here are two examples of what I meant for posible transitions that are
"spliced" as I tried to describe it rather than a smooth fade. (I think
the smooth fade that Thomas suggested and you have managed so far is
quite effective, btw.) Each of these examples is arrived at differently
and probably rather crudely but my larger point is that there is not a
single answer to either look or method to what I meant.  I am just
popping an image_map in to stand for  the night v day backgrounds you
have.  If you are rendering them directly of course, each of the methods
I use here could be resolved into a pigment_pattern which could then be
used with MegaPOV's camera pigment.
I'll put the SDL on p.b.scene-files
As for the floor I'll noodle on it a bit further
-Jim
Download '1.png' (334 KB) Download '2.png' (307 KB)
Preview of image '1.png'
Preview of image '2.png'
Date: 1 Nov 2008 08:26:42
Message: <ujiog4lhhm2urn7jko9g1eic9v9kuqibt9@4ax.com>
Date: 1 Nov 2008 11:45:58
Message: <490c79b6$1@news.povray.org>
Hmmm... Nice. I like the first one better. Perhaps a more symbolic
splice tho?  Little 8-fold wheels or Tao-shape spirals?
Date: 1 Nov 2008 15:02:21
Message: <490ca7bd$1@news.povray.org>
Date: 1 Nov 2008 15:13:27
Message: <490caa57@news.povray.org>
Download '2.png' (1 KB) Download 'f2.jpg' (74 KB) Download 'f1.jpg' (136 KB) Download 'f3.jpg' (108 KB)
Preview of image 'f2.jpg'
Preview of image 'f1.jpg'
Preview of image 'f3.jpg'
Date: 1 Nov 2008 16:46:14
Message: <1vfpg4pl49lk4655vgtdeo1q3v6vtsmmel@4ax.com>
Date: 1 Nov 2008 22:37:37
Message: <490d1271@news.povray.org>
Jim Charter nous illumina en ce 2008-11-01 01:45 -->
>> using a
>> bit. (Beta
>> to blend
>> lines of
>> faces
>> don't match up.
> well.
> -Jim
I prefer the top one. The bottom one looks to "geometric"...
Make yourself a better person and know who you are before you try and know
someone else and expect them to know you.
Date: 6 Nov 2008 11:55:00
Message: <web.49132053390cc5e3d0bdfd6f0@news.povray.org>
> Regards
>      Stephen
Nice !
Would youo mind sharing where you got / or the source code of the budda?
Date: 7 Nov 2008 04:12:27
Message: <dj18h4923mgchj3uvvqjj8evnvtqq9oksm@4ax.com>
>> Regards
>>      Stephen
>Nice !
Sorry for the delay
Search for budda
Regards
Date: 17 Jan 2009 12:00:03
Message: <web.49720d68390cc5e3d0bdfd6f0@news.povray.org>
> >> Regards
> >>      Stephen
> >Nice !
> Sorry for the delay
> Search for budda
> Regards
>      Stephen
How were you able to convert from the 3dxml format?
Date: 17 Jan 2009 13:34:16
Message: <st84n41vm9udcvfs5dd6v3h39ielq6rplv@4ax.com>
>> Sorry for the delay
>> Search for budda
>> Regards
>>      Stephen
I didn't. I downloaded the 3ds format ;)
http://www.3dvia.com/MichelAngelo/models/F516D9EBFDCFE1F3
Click "download" and select.
Original 3ds File (1.17 MB)
Then register to download.
Regards
Date: 20 Jan 2009 07:20:01
Message: <web.4975c074390cc5e3aefa83390@news.povray.org>
> >> Sorry for the delay
> >> Search for budda
> >> Regards
> >>      Stephen
> Regards
>      Stephen
Forgive my ignorance, what program did you use to convert from 3ds. Is it
free/open source I currently only know of one shareware program, and I am not
particularly keen on using it since it goes against my hippie philosophy of
promoting open source.
Date: 20 Jan 2009 07:42:12
Message: <4975c6a4@news.povray.org>
"Woody" <nomail@nomail> schreef in bericht
news:web.4975c074390cc5e3aefa83390@news.povray.org...
> not
> of
Poseray does the job  :-)
Date: 20 Jan 2009 07:45:00
Message: <web.4975c627390cc5e3bdd9e4330@news.povray.org>
I guess you're not running Windows; otherwise I could recommend - without
thinking - two free tools that do both 3ds import and POV export: Wings 3D and
PoseRay.
For Linux, you may want to try the Wine / PoseRay combo. PoseRay claims to be
running perfectly fine on Wine. Cheers!
Date: 20 Jan 2009 08:32:57
Message: <d9kbn4ll0lb5964mjui56c9jdoe8qrka8e@4ax.com>
That is three of us voting for PoseRay, which can be run under Wine, if you are
using Linux. There is no mention of a licence that I can find.
http://mysite.verizon.net/sfg0000/
And this old hippy wants to know what's wrong with "open source"?
Regards
