POV-Ray : Newsgroups : povray.binaries.images : Remake in progress (RIP? :) - 109Kb Server Time
21 Oct 2026 04:26:03 EDT (-0400)
  Remake in progress (RIP? :) - 109Kb (Message 1 to 19 of 19)
Subject: Remake in progress (RIP? :) - 109Kb
Date: 17 Aug 2003 07:44:25
Message: <20030817134439.76d77bcd.jaimevives@ignorancia.org>
Hi All:
  Trying to recover from a long lack of inspiration, I started a
"remake" of my old scene "fuente". This was a kind scene that I always
wanted to try with radiosity.
  I've not resited the temptation to do a "full rewrite" of the code
(still in progress). I used POV-Tree + TOMTREE for the nice palms
(thanks Gena & Tom!) and a modified Skylight.inc for the sky (thanks
Philippe!).
  Critcism welcomed as usual!
Jaime Vives Piqueres
http://www.ignorancia.org
Download 'fuente-wip.jpg' (109 KB)
Preview of image 'fuente-wip.jpg'
Subject: Re: Remake in progress (RIP? :) - 109Kb
Date: 17 Aug 2003 08:30:52
Message: <3f3f757c@news.povray.org>
Hi James,
I surely like the image. You're an expert in light and fine CSG modelling!
Personally, I would give the image more dynamic compression, to brighten the
building and the trees. Maybe the building is also a tad too blue and cold.
On a technical note, my first interpretion was that not enough sunlight
bounces off from the ground onto the walls, so all we have left is skylight.
After a closer look I realize it does bounce, as can be seen on the snip of
the building at the upper left.
But I would probably try increasing radiosity brightness and lowering the
skylight, or just adjust the white-balance. I would also use Kari Kivisalos
exposure control to avoid the sunlit area gets brighter than it already is.
The building seems as much in focus as the water fountain. The space
allocated for the building is rather big, and so the overall impression is
dark.
Hugo
Date: 17 Aug 2003 08:37:11
Message: <3f3f76f7$1@news.povray.org>
Hola Jaime,
I only have one remark : the shape of the falling water doesn't seem
physically accurate, it doesn't have enough speed to get out
horizontally like this, it should be falling much faster.
Apart from this little detail, this image is REALLY nice.
I can feel the freshness of the shadow in this very hot spanish afternoon.
JC
Jaime Vives Piqueres wrote:
> Hi All:
> Philippe!).
Date: 17 Aug 2003 09:38:04
Message: <3F3F853B.9F95FE00@gmx.de>
> Hi All:
> Philippe!).
Looks very good although the detail level of course is not suited for a
much larger render.  It is crying out loud for being rendered in HDR file
format though (so you can turn up the brightness and view the shadow parts
as well).  You could also render a nice light probe from it...
The palms are double_illuminate i assume?
BTW if you have a nicely working version of the skylight include file it
would be great if you could share it.  The one posted in p.b.s-f. seems to
be buggy in some ways and i have not yet found the patience to work though
all the suggestions for fixes etc. that have been posted in reply.
Last updated 17 Jun. 2003 _____./\/^>_*_<^\/\.______
Date: 17 Aug 2003 10:03:11
Message: <Xns93DAA34D84DE9raf256com@204.213.191.226>
chr### [at] gmxde news:3F3F853B.9F95FE00@gmx.de
> a much larger render.  It is crying out loud for being rendered in HDR
> file format though (so you can turn up the brightness and view the
> shadow parts as well).  You could also render a nice light probe from
> it...
Can I do it with Pov 3.5 or do I need patch (and where to get it from)?
Date: 17 Aug 2003 11:27:46
Message: <3f3f9ef2@news.povray.org>
"Jaime Vives Piqueres" <jai### [at] ignoranciaorg> wrote
Use parabolic paths for water (with very small horizontal velocity). The
curent filleted-L flow is unnatural and distracting.
Date: 17 Aug 2003 12:47:10
Message: <3F3FAF75.2080002@mail.com>
Nice image (as usual :)
I can just recommend how to imrove your palms. Maybe it's not
so bad for low resolution but mesh leaves will be too annoying in
high resolution.
The best result you can achieve using Tom Aust's heightfield
leaves (HF_PALMLEAF...) In this case you cannot save mesh
tree from POV-Tree but you can use TOMTREEm (included
with POV-Tree 1.2) to render the trees. It will reduce rendering
time. Also you will need leaf image map from original TOMTREE.
If you still prefer to use mesh leaves try to use the latest version
of POV-Tree 1.2. I fixed there a bug related to Mesh1 leaf. Now
it's triangular structure is not so visible because one side of the
triangle lays on branch.
For mesh leaves you could try also the following settings which
hopefully should help :)
Branch tab - Taper = 1.0
Bunch tab  - Taper Off At Tree = -0.3
Bunch tab  - Taper Off At Twig = -1.5
Gena.
Date: 18 Aug 2003 02:45:04
Message: <fbt0kv0mtisq6i46m1h69vr8l2okk48b8c@4ax.com>
On 17 Aug 2003 10:03:11 -0400, "Rafal 'Raf256' Maj" <spa### [at] raf256com> wrote:
> > it...
http://www.google.com/search?q=POV+HDR !
ABX
Date: 18 Aug 2003 16:04:54
Message: <3f413166$1@news.povray.org>
Wow. This looks fantastic. I look forward to a more
finished/larger/higher quality version. :D
One bit of advice I can think of: you might want to add some kind of
texture to the palm leaves, as they look pretty bland right now and you
can really see it in the foreground.
-Xplo
Date: 18 Aug 2003 16:51:48
Message: <3f413c64$1@news.povray.org>
Ah, columns and arches. My favourites.
Beautiful image, but one thing bothers me: shouldn't the shape of the
water squirts be more parabolic like, than the
quater-circle-and-straight that it seems to be now?
/Ib
Date: 19 Aug 2003 04:59:40
Message: <20030819110009.1c88393c.jaimevives@ignorancia.org>
Hi Hugo:
> brighten the building and the trees. Maybe the building is also a tad
> too blue and cold. On a technical note, my first interpretion was that
> not enough sunlight bounces off from the ground onto the walls, so all
> we have left is skylight. After a closer look I realize it does
> bounce, as can be seen on the snip of the building at the upper left.
  Well, it has poor quality rad settings for now. Recursion limit is 1,
so the light bounces mainly from the sky. I will try 2 for the final
render, if I can't wait that long...
> the skylight, or just adjust the white-balance. I would also use Kari
> Kivisalos exposure control to avoid the sunlit area gets brighter than
> it already is.
  I'm planning to save rad data with a much brighter light, so it will
improve the shadowed parts. If this doesn't work I must finally start
using MegaPOV...
> impression is dark.
  Well, the camera is the same as the original scene... and I like it.
The main subject, even if the name doesn't suggest it, it's the "patio".
  Thanks!
Date: 19 Aug 2003 04:59:50
Message: <20030819110019.79e9e12f.jaimevives@ignorancia.org>
On Mon, 18 Aug 2003 13:05:05 -0700
> you can really see it in the foreground.
  Yes, I think I will follow Gena advice about using hf leaves instead.
  Thanks!
Date: 19 Aug 2003 05:00:05
Message: <20030819110028.37a43a0c.jaimevives@ignorancia.org>
Hi JC:
  Ah, yes... the current object is a placeholder (torus+cylinder).
> afternoon.
  Thanks!
Date: 19 Aug 2003 05:00:14
Message: <20030819110043.654d4653.jaimevives@ignorancia.org>
On Sun, 17 Aug 2003 09:38:13 -0700
> high resolution.
  Thanks for all the tips! I'm just playing with them... will see soon
the result. Regards..
Date: 19 Aug 2003 05:03:12
Message: <20030819110340.7df7c7a4.jaimevives@ignorancia.org>
Hi Christoph:
  Yes, but only for the moment... :) Anyhow the final render will not be
very big. I heavily use the low resolution to hide my lazyness. :(
> it...
  Again, I must try MegaPOV...
  Of course! I think it works prety well for leaves. There is also a bit
of filter.
> it would be great if you could share it.  The one posted in p.b.s-f.
> seems to be buggy in some ways and i have not yet found the patience
> to work though all the suggestions for fixes etc. that have been
> posted in reply.
  Well, I don't know if the version I have is really a "working one".
That is, I don't know if it really follows perfectly the original
algoritm. But it surely gives results very similar to the images from
the original paper.
  Mine is a version revised by Ive (I've done nothing here) to use his
CIE.inc included on Lightsys. Philippe allowed it to be part of the next
Lightsys version, wich I will release soon (as always, making the docs
and examples is a real pain...).
  Thanks for the comments!
Date: 19 Aug 2003 05:03:41
Message: <20030819110409.0abd4505.jaimevives@ignorancia.org>
On Sun, 17 Aug 2003 09:32:13 -0600
> The curent filleted-L flow is unnatural and distracting.
  Yes, I think I will use a blob with slighty randomized components
following a parabolic spline... any better idea?
Date: 19 Aug 2003 06:28:32
Message: <20030819122900.18b795aa.jaimevives@ignorancia.org>
Hi Ib:
  Yes, it's a mistery why they are so attractive... I like particulary
cloister patios, as the image shows.
  About the water, sorry for the crappy placeholder...
  Thanks!
Date: 19 Aug 2003 06:38:03
Message: <3F41FE0A.173C3CD6@gmx.de>
> > it...
Well, MP 1.0 does not help you there - still it would be an intereating
image for this.  If you want to get an idea how it looks feel free to send
me the source to render it as HDR.
Looking forward to it...
I know, currently working on the next isowood when time permits but it can
be really lots of work as soon as things are a bit more complicated.
Date: 19 Aug 2003 19:13:38
Message: <3f42af22$1@news.povray.org>
Wow, very nice image Jaime!  The radiosity really came out nice.
Doug Eichenberg
www.getinfo.net/douge
dou### [at] nlsnet
