POV-Ray : Newsgroups : povray.binaries.images : New signature (95K PNG) Server Time
16 Oct 2026 13:19:08 EDT (-0400)
  New signature (95K PNG) (Message 1 to 16 of 16)
Subject: New signature (95K PNG)
Date: 5 Mar 2003 19:55:16
Message: <1cjs09m6sfo9.3t4w4o7j3dal.dlg@40tude.net>
Hullo, I've decided to join the guild and make a condensed code signature.
This is actually my first "odd ball" scene I've made and it took me less
than an hour.
Download 'ge_sig_1.png' (96 KB)
Preview of image 'ge_sig_1.png'
Subject: Re: New signature (95K PNG)
Date: 5 Mar 2003 20:01:38
Message: <q01sd8bweehb$.1xuwuayt3yygc$.dlg@40tude.net>
There, now you can actually see it.
camera{location 2*y-.9rotate -9*z look_at y direction z/1.5}global_settings
{max_trace_level 99ambient_light 10}#macro P(o,c)plane{y,o pigment{c}finish
{diffuse 0}}#end object{P(9,blue 1)}object{P(-1,rgb 1)}box{1+9*y,-1-y
pigment{rgb 1}finish{ambient.005diffuse 0 reflection .95}}sphere{0,.99
finish{reflection 1}}sphere{0,1pigment{red 1}finish{ambient 0reflection{1
metallic}}no_reflection} // Greg Edwards, 2003
Date: 5 Mar 2003 20:15:52
Message: <1covq318i6ncq.np7e6ff37v1j.dlg@40tude.net>
Gah, I've just made it but I've already managed to condense it a bit
more... See below:
camera{location 2*y-.9rotate -9*z direction z/1.5look_at y}global_settings{
max_trace_level 99ambient_light 10}#macro P(o,c)plane{y,o pigment{c}finish{
diffuse 0}}#end object{P(9,blue 1)}object{P(-1,rgb 1)}box{1+9*y,-y-1pigment
{rgb 1}finish{ambient.005diffuse 0 reflection .95}}sphere{0,.99finish{
reflection 1}}sphere{0,1pigment{red 1}finish{ambient 0reflection{1metallic}
Date: 5 Mar 2003 20:20:13
Message: <1d11anxf4bf76$.1jpm3ygesihaq.dlg@40tude.net>
A bit more...
{rgb 1}finish{ambient.005diffuse 0reflection.95}}sphere{0,.99finish{
Date: 6 Mar 2003 02:47:32
Message: <d0vd6vcbe7gl6kc7p7ti374dek94gfsal3@4ax.com>
On Wed, 5 Mar 2003 20:22:29 -0500, Greg Edwards
<edw### [at] hotmailcomremovethis> wrote:
> A bit more...
I feel this can be shortened (in particual camera) but this is already shorter
and does not produce warning.
camera{direction z/1.5location 2*y-.9rotate-z*9look_at y}global_settings{
max_trace_level 99ambient_light 10}#macro p(c,d,a,r)pigment{rgb c}finish{
diffuse d ambient a reflection{r#end plane{-y,-9p(z,0,.1,0)}}}plane{y,-1p
(1,.0.1.0)}}}box{-y-1y*9+1p(1,.0.005.95)}}hollow}sphere{.0.99p(no.6.1on)}
}}sphere{0,1p(x,.6,0,1)metallic}}no_reflection} // Greg Edwards, 2003
Please, note sig is supposed to represent author. How reflective spheres
represent your person ? :-)
ABX
disc{z,-z#macro O()asc(substr("-+((1*(,1,/.-,*/(,&.323/'1"e 1))/10-4#declare
e=e-1;#end#local e=26;5pigment{#local g=function(_){ceil(_)-_}function#local
k=function{pattern{object{sphere_sweep{linear_spline 13#while(e)<O()O()>.01#
end}}}}{k(g(atan2(x,y)),g(ln(pow(x+y,2)+1e-5)),0)}}finish{ambient 1}}//ABX35
Date: 6 Mar 2003 10:19:14
Message: <3qmyu17rfd6n$.1010eya7grle4.dlg@40tude.net>
>> A bit more...
> ABX
I've often felt isolated from others in the group often, this is what I'm
trying to represent in the scene. Also, abstract scenes are just my style
:-) You can't really see that the red ball is all alone but that's because
I couldn't place it outside the 2x2 area of the mirrors.
camera{location 2*y-.9rotate -z*9direction z/1.5look_at y}global_settings{
Date: 6 Mar 2003 10:21:27
Message: <3e676777@news.povray.org>
"ABX" <abx### [at] abxartpl> wrote in message
news:d0vd6vcbe7gl6kc7p7ti374dek94gfsal3@4ax.com...
> > A bit more...
y}global_settings{
pigment{c}finish{
shorter
He's an oddball?  That would work for me.
Date: 6 Mar 2003 10:34:55
Message: <mfqe6vcqs2g8il8fde8teaqaqtquveh15s@4ax.com>
On Thu, 6 Mar 2003 10:21:36 -0500, Greg Edwards
You will be isolated even more with such a long sig :-) While writing sigs
is fun and educational, your version is far from acceptable length. Please
do not use it. Force yourself to make another sig which fits rules. Have fun
with it :-)
ABX
Date: 6 Mar 2003 11:37:42
Message: <9ez7rng4lv76$.1ac00mmx79n1u$.dlg@40tude.net>
>>> A bit more...
> y}global_settings{
> pigment{c}finish{
> shorter
Right on! :-)
Date: 6 Mar 2003 11:44:05
Message: <gy5nsxf1ql0p$.7f9awqpf22c7$.dlg@40tude.net>
> with it :-)
> ABX
Fits the rules? I don't recall any rules for what can go in your signature.
IIRC, the Shortest Code Contest allows for a maximum of 500 bytes which
this easily fits in. The actual signature is 416 bytes but could easily be
condensed to 382 if I removed the line breaks and took out the comment.
Having fun with it is what I did! :-)
Date: 6 Mar 2003 11:52:05
Message: <qnue6vkhqnngsb45a3hsmiupaaf081q4jo@4ax.com>
On Thu, 6 Mar 2003 11:44:06 -0500, Greg Edwards
http://www.uwasa.fi/~ts/http/signatur.html
You are mistaken. Shortest Code Contest never mentioned it makes rules for
signatures. It was not Shortest Signature Contest. In particular please look
at one rule in Shortest Code Contest: "MAX size: 500 bytes (arbitrarily
chosen as twice the size of one very competent sig file posted to p.g.)".
That's the most important :-)
ABX
Date: 6 Mar 2003 12:59:28
Message: <nm4fgwbmgwgf$.1wwoeb9v1ghu0$.dlg@40tude.net>
>>> A bit more...
>> ABX
One more thing, when I said "the group," I meant groups in general, not
this newsgroup. I was just really rushed when I posted that message and I
couldn't think of a better word.
BTW, I've done a super shrink job on my sig. (this one is now 375 bytes)
max_trace_level 99ambient_light 10}#macro G(V,E)pigment{V}finish{diffuse 0
ambient .1-E/10reflection{E metallic}}#end#macro O(N,T)plane{y,N G(T,0)
hollow}#end#macro C(A)sphere{0,A#end O(9,blue 1)O(-1,rgb 1)box{1+9*y,-y-1G(
rgb 1,.95)hollow}C(.99)G(rgb 1,1)}C(1)G(red 1,1)no_reflection}// Greg E
Date: 6 Mar 2003 13:15:04
Message: <web.3e678f0d9b3d568b8ae0d1080@news.povray.org>
You have repeated things I already shortened in this thread. Have you
noticed them ? :-)
ABX
Date: 6 Mar 2003 13:20:53
Message: <mkiqgpumpb2l$.irlups1nomyo.dlg@40tude.net>
> noticed them ? :-)
> ABX
Yes I did and I also realized that your version of the pigment macro took
an unnecessary diffuse value which is always zero and I believe my
auto-ambient takes a few less bytes in the long run.
PS. Funny how we're arguing over bytes! :-)
Date: 6 Mar 2003 13:22:55
Message: <1jk8x5nnrtm10$.jnikfma6i5w1$.dlg@40tude.net>
>> noticed them ? :-)
>> ABX
Whoops, forgot to give you credit! The texture macro was your idea!
Date: 10 Mar 2003 16:04:13
Message: <1syi7oz8k84hs.1qsbz2hv1n6gt$.dlg@40tude.net>
How's this for indecision? I've compacted my old signature down to 4 lines
of 75. (302 bytes)
camera{location 2*y-.9direction z/1.5look_at y rotate#macro G(V,E)plane{y,V
O(E,0)}#end-z*9}max_trace_level 99#macro O(N,T)pigment{rgb N}finish{diffuse
0ambient 1-T reflection{T metallic}}#end#macro C(A)sphere{0A#end G(9z)G(-1,
1)box{1+9*y,-y-1O(1,.95)}C(.99)O(1,1)}C(1)O(x,1)no_reflection}// Greg E
light_source#macro G(E)sphere{z+E*y*5e-3.04rotate-z*E*6pigment{rgbt#end{
20*y-10#local n=162;1}#while(n)#local n=n-.3;G(n)x}}G(-n).7}}#end//GregE
