POV-Ray : Newsgroups : povray.binaries.images : profile following a parametric curve : Re: profile following a parametric curve Server Time
29 Mar 2026 09:56:09 EDT (-0400)
Date: 2 May 2025 10:20:00
Message: <web.6814d401174259623d0038515cc1b6e@news.povray.org>
kurtz le pirate <kur### [at] freefr> wrote:
> hello,
> My first attempts.
> Curves are defined with Cartesian parameters: x=f(t), z=g(t).
> The profile is a simple polygon.
> Basic texture, lighting with area_light.
> Low resolution (800x600).
> kurtz le pirate
> compagnie de la banquise
Do you adjust the size of your profile object as you follow the curve, or does
it just have a very tiny thickness at each t step?  When I use this technique, I
struggle with getting the resulting object smooth if the curves are wide.
-- Chris R
