POV-Ray : Newsgroups : povray.binaries.images : 6 simple plants : Re: 6 simple plants Server Time
21 Mar 2026 16:37:14 EDT (-0400)
  Re: 6 simple plants
Date: 12 Nov 2023 09:40:00
Message: <web.6550e25bea5e3361f22cdb33dabc9342@news.povray.org>
> >>> 6 plants made from smooth triangle billboards. These render much faster than the
> >>> clipped sphere approach I was originally using. Scene file posted.
> >>> Miller
> >> Those are nice. Make them into mesh to use the instanciation feature of
> >> the meshes.
> >> So, instead of :
> >> #declare ST_leaf =
> >>      union {
> >>       //--left 1/2
> >>       smooth_triangle { p11, n1, p4,  n1, p6,  n1 }
> >>       smooth_triangle { p11, n1, p10, n1, p4,  n1 }
> >>       smooth_triangle { p9,  n1, p10, n1, p11, n1 }
> >>       smooth_triangle { p9,  n1, p8,  n1, p10, n1 }
> >>       smooth_triangle { p15, n1, p8,  n1, p9,  n1 }
> >>       smooth_triangle { p15, n1, p14, n1, p8,  n1 }
> >>       smooth_triangle { p2,  n1, p15, n1, p5,  n1 }
> >>       smooth_triangle { p2,  n1, p14, n1, p15, n1 }
> >>       //--right 1/2
> >>       smooth_triangle { p11, n5, p3,  n5, p12, n5 }
> >>       smooth_triangle { p11, n5, p6,  n5, p3,  n5 }
> >>       smooth_triangle { p9,  n5, p12, n5, p7,  n5 }
> >>       smooth_triangle { p9,  n5, p11, n5, p12, n5 }
> >>       smooth_triangle { p15, n5, p7,  n5, p13, n5 }
> >>       smooth_triangle { p15, n5, p9,  n5, p7,  n5 }
> >>       smooth_triangle { p1,  n5, p15, n5, p13, n5 }
> >>       smooth_triangle { p1,  n5, p5,  n5, p15, n5 }
> >> Use this :
> >> #declare ST_leaf =
> >>      mesh{
> >>       //--left 1/2
> >>       //--right 1/2
> >> That way, you can place 1000's of copies of the same plant that'll use
> >> only the storage for a single one.
> > Alain,
> > thank you so much! I will definitely fix that. It's been a long time since I
> > worked with triangles in POV...
> > I have a new problem ..haha. Now that I've converted these billboards to smooth
> > triangles, I'm getting a new fog bug showing up in reflections. I'm posting a
> > snippet of a rendering I did last night using these plants in my nest scene.
> > Billboards that cross in front the water renders without fog. Strange...may just
> > give up on using them in this scene. :-)
> > Mike
> Triangles do have an interior and an exterior. Try using hollow. It MAY
> help... Or not.
> mesh{ ...
>   hollow
> Next, you may be faced with the tracing and sampling of that fog. Here,
> the presence or absence of turbulence is probably not a factor.
> You may need to use scattering media with the render time taking a
> serious hit.
> But, yes. Fog and media tend to not play nice with transparency.
Just tried your suggestion of using hollow in the mesh statement - It worked!
Thank you so much...just about to give up. :-)
Mike.
Download 'triangles_working.png' (910 KB)
Preview of image 'triangles_working.png'
