POV-Ray : Newsgroups : povray.binaries.images : billboard tint : Re: billboard tint Server Time
27 Mar 2026 14:53:11 EDT (-0400)
  Re: billboard tint
Date: 7 Nov 2023 07:25:00
Message: <web.654a2c6d310e11e9b4924336e066e29@news.povray.org>
"Mike Miller" <mil### [at] gmailcom> wrote:
> I found the problem. It turns out that if add even a small amount of turbulence
> (.3 or more) to the fog definition - it tints the alpha portion of the image
> map. I set the turbulence to zero and it cleared it up. I'm not sure why, but it
> worked.
Yeah, that's a strange problem; I'm glad you found a solution.
> #declare sprite = box {<-.5,0,-.01>,<.5,1,.01> } ;
> object { sprite material {M_grass_A} scale <30,40,1> translate <0,-1,0>}
Just thought I would mention that you can make a box object with zero thickness,
which might be better for billboards. I usually use that trick.
#declare sprite = box {<-.5,0,0>,<.5,1,0> };
I wonder if that would have any effect on your original problem.
A box can't be *scaled* to have zero-thickness, but it can be made that way
initially.
