POV-Ray : Newsgroups : povray.binaries.images : brain bot progress rendering : Re: brain bot progress rendering Server Time
20 Mar 2026 06:48:14 EDT (-0400)
Date: 20 Jul 2023 14:35:00
Message: <web.64b97d3141b179efb5177e91dabc9342@news.povray.org>
> > > > Current modeling progress for a brain bot character. [...]
> > > It's looking really good!
> > > How are you modeling the brain?
> > Thanks,
> > the brain is one continuous sphere_sweep/cubic_spline. I used Blender with
> > object snap to plant spheres on a simple brain shape surface. I image-mapped the
> > surface to help guide the process of plotting out the gray matter folds. I
> > exported the spheres via .x3d and converted the file to POV syntax. Attached is
> > a capture of the brain in Blender. Still tweaking a bit. I'm only modeling what
> > I the final camera will see. I'm currently working on the weapon at the end of
> > the tenacle arms.
> > Mike
> Ah, tracing the brain folds is a good solution, for sure.
> I know nothing about the .x3d file type, but it sounds like it somehow preserves
> lots of info including ordered point arrays? Or it can at least be converted to
> arrays?
> Sam
In Blender, I array a sphere along a bezier path with the 'curve' modifier.
Collapsing the array and curve moodier to create a list of loose elements still
maintains a creation order. Prefect for lathes, sweeps, prisms, ect.
Miller
