POV-Ray : Newsgroups : povray.binaries.images : Oscilloscope : Re: Oscilloscope Server Time
19 Mar 2026 09:09:10 EDT (-0400)
  Re: Oscilloscope
Date: 6 Feb 2023 13:30:00
Message: <web.63e146b833e903b1f9dae3025979125@news.povray.org>
William F Pokorny <ano### [at] anonymousorg> wrote:
> I too forgot about the no_radiosity keyword! I believe this the better
> approach to make the screen invisible to radiosity rays, but as you said
> it would need to be built in such a way all the glowing bits are
> represented as stand alone objects such that the keyword could be used.
I professional photography, they will use an-off camera reflector for
fill-lighting.
Can the reverse be done?  What if you shielded the screen with a black square or
mesh, and used no_object so that it wasn't visible?  Or something semi-opaque
that would still allow lighting, like a diffuser on a light-bulb?
This is a beautiful scope model, and the animated lissajous curves are nice  :)
- BE
