POV-Ray : Newsgroups : povray.binaries.images : Using "transmit all" with an image map : Re: Using "transmit all" with an image map Server Time
31 Mar 2026 06:18:32 EDT (-0400)
Date: 29 Dec 2022 20:30:00
Message: <web.63ae3ec1eaa53b9ce22848419334df62@news.povray.org>
"Tor Olav Kristensen" <tor### [at] TOBEREMOVEDgmailcom> wrote:
> Hi Dave
> Have you considered using ImageMagick to adjust the transparency levels
> in your images?
> https://imagemagick.org
> ImageMagick provides command line tools that can be used in shell scripts
> to automate such time consuming tasks.
> https://imagemagick.org/script/magick-script.php
> Perhaps this post is relevant for solving your problem:
> "Setting an image to 50% transparency"
> https://legacy.imagemagick.org/discourse-server/viewtopic.php?t=31549
> Tor Olav
> http://subcube.com
> https://github.com/t-o-k
This looks like a really useful program. I see the copyright is 1999 but I seem
to recall a program with the same or similar name from even earlier than that,
which was a DOS command-line program that operated on images. I used it quite a
bit to convert graphics formats. I wonder if this is an evolution of that DOS
program. Thanks for pointing it out.
