POV-Ray : Newsgroups : povray.binaries.images : Crackle again : Re: Crackle again Server Time
18 Mar 2026 13:05:25 EDT (-0400)
  Re: Crackle again
Date: 24 Nov 2022 11:00:00
Message: <web.637f94a9c37f1de01f9dae3025979125@news.povray.org>
> Sorry; the previous crackle thread from a couple of days ago, with the custom
> version you showed that just colors a point based on distance to the closest
> seed point.
http://news.povray.org/povray.binaries.images/message/%3Cweb.6376dd8c302862a41f9dae3025979125%40news.povray.org%3E
Ah.  "Colors" meaning simple scalar grayscale shading.
> > > The documentation even mentions using a solid crackle with a regular crackle
> > > layered over it to generate mortar for the solid cells.
I think what they mean is the reverse?
"There is no provision for mortar, but mortar may be created by layering or
texture-mapping a standard crackle texture with a solid one."
It's been a while since I've messed with that, and their language there is a
little - vague.
> > Also wondering if, with your existing knowledge of how your code works, if
> > there was a way to "draw lines" with cylinders around the borders of the
> > cells. Something to do with the mesh vertices perhaps....
> Hmm that's a thought. It would consist of a large quantity of spheres and/or
> cylinders placed around each mesh base, all as a single object pattern.
I was actually thinking not as an object pattern, but as the native lattice of
cylinders.  Make a scene with small spheres as the center points, and make the
Voronoi with cylinder{} objects.
AND, if that's possible - then why not do the Voronoi with prism {} objects.
Then they can all be collected into an array and textured however one wants -
even manually, one at a time.
But there is obviously much to played with here.   How does it look if instead
of using cones, we use spheres, ellipsoids, superellipsoids, pyramids, etc?
http://www.f-lohmueller.de/pov_tut/all_shapes/shapes3_0000e.htm
http://www.f-lohmueller.de/pov_tut/all_shapes/shapes350e.htm
While researching this, I have also seen people use other distance metrics, such
as the "Manhattan distance" or "taxicab distance", etc.
