POV-Ray : Newsgroups : povray.binaries.images : Crackle again : Re: Crackle again Server Time
29 Mar 2026 13:33:12 EDT (-0400)
  Re: Crackle again
Date: 23 Nov 2022 08:35:00
Message: <web.637e2164c37f1de0b96893c06f35e431@news.povray.org>
> Hi everyone
Code for the curious:
#declare BrightFn = function { pigment {
 wood color_map { [0 rgb 0] [1 rgb 1] } rotate x*90 scale 6
#declare N = 250;
#declare Sd = seed(0);
#declare D = 10;
#declare Points = array[N];
#declare Cones = array[N];
#for (I, 0, N-1)
 #declare Points[I] = <rand(Sd)*20-10, 0, rand(Sd)*20-10>;
 #declare Cones[I] = cone { Points[I]-y*D, 10, Points[I], 0 }
#declare OtherCones = array[N];
#for (I, 0, N-1)
 #declare OtherCones[I] = union {
  #for (J, 0, N-1)
   #if (J != I) object { Cones[J] } #end
  plane { y, -D } // to catch misses
#declare NS = 250;
#declare DA = 360/NS;
#declare MeshCells = array[N];
#for (I, 0, N-1)
 #declare MeshCells[I] = mesh {
  #for (IA, 0, NS-1)
   #declare V1 = vrotate(<1,-1,0>, y*DA*IA);
   #declare V2 = vrotate(<1,-1,0>, y*DA*(IA+1));
   #declare P1 = trace(OtherCones[I], Points[I], V1);
   #declare P2 = trace(OtherCones[I], Points[I], V2);
   triangle { Points[I], P1, P2 }
   triangle { P1, <P1.x, -D, P1.z>, <P2.x, -D, P2.z> }
   triangle { P1, <P2.x, -D, P2.z>, P2 }
   triangle { Points[I]-y*D, <P2.x, -D, P2.z>, <P1.x, -D, P1.z> }
  inside_vector y
#declare Fns = array[N];
#for (I, 0, N-1)
 #declare Fns[I] = function {
   object {
    MeshCells[I]
    rgb 0, rgb BrightFn(Points[I].x, -D+1e-4, Points[I].z).x
#declare WholeFn = function {
 max(
  #for (I, 0, N-1)
   Fns[I](x, -D+1e-4, z).x
   #if (I < N-1) , #end
box {
 <-10, -0.01, -10>, <10, 0, 10>
 pigment { function { WholeFn(x, y, z) } color_map { [0 rgb 0] [1 rgb 1] } }
 finish { diffuse 0.8 ambient 0 }
