POV-Ray : Newsgroups : povray.binaries.images : Moonlight : Re: Moonlight Server Time
31 Mar 2026 02:16:33 EDT (-0400)
  Re: Moonlight
Date: 28 Mar 2022 11:10:00
Message: <web.6241cf0997e56063cc71334a5cc1b6e@news.povray.org>
"Mr" <m******r******at_hotmail_dot_fr> wrote:
> "Chris R" <car### [at] comcastnet> wrote:
> > Alain Martel <kua### [at] videotronca> wrote:
> > > > Op 27/03/2022 om 06:23 schreef Chris R:
> > > >> When I rendered this as 1920x1080, I realized I had the camera in the
> > > >> wrong
> > > >> position, (forgot to account for a "floor thickness"), so the camera
> > > >> was too low
> > > >> aspect ratio.
> > > >> Here is a version that fixes that, and makes it much less dark.
> > > >> -- Chris R.
> > > > Indeed.
> > > > what are those light points beyond the blinds?
> > > My guess : a texture from skys.inc applied to a sky_sphere and no actual
> > > ground outside.
> > You stole my thunder!
> > Pretty close; I don't use skys.inc, but I rolled my own star-sphere and forgot
> > to put a ground plane outside the window.
> > However, I haven't gone to fix it, because it also looks like the room is in a
> > tall building looking out over city lights, so I decided to keep it that way.
> > -- Chris R.
> I like the first shot, and also the sheve with plant composition, even better.
> Such a scene should be unforgiving to non linearworflows (gamma 1 +srgb colors +
> inverse square lights attenuation (new _0 model) + postrendered gamma 2.2)
> Did you use no radiosity at all? because all of it seems really too dark. if you
> activate it, make sure to give the sky_sphere a night horizion tint. An overall
> raileigh scattering media may help the moonlight source bleed wider, and maybe
> bloom slightly from side of the frame if placed properly.
I do have radiosity enabled, although I haven't influenced it with the sky
sphere at all.  I have probably confused things with multiple versions of the
same scene in these discussions, so do you find even the latest chess board
closeup, (the 1920x1080 version) too dark for a moonlit scene?  The earlier
versions had the camera too low, so too much of the scene was in the shadow.
-- Chris R.
