POV-Ray : Newsgroups : povray.binaries.images : Stone with Veins : Re: Stone with Veins Server Time
18 Mar 2026 08:58:14 EDT (-0400)
Date: 31 Dec 2021 00:50:00
Message: <web.61ce98d1c205c2d42636f1af607c1b34@news.povray.org>
> I took my Granite_21 array for Dakota Red and extracted colour pairs. I
> also changed the reflection block because I guess the original
> reflection is way too strong. I used the reflection as given in
You would be shocked at what a mess I've made of the lighting and texturing in
the scene that this came from so yes the finish would need a lot of fixing. I've
always had trouble with that part of POV-Ray...
> I used 10 layers and scaled the final texture on the object. I could
> also have used much more layers (e.g. 100) and scale the texture
> somewhat less, with a similar result but a bit more confused imo.
Ten layers is much more reasonable than a hundred and your excellent results
prove it. I admit that a hundred layers is a bit of overkill. (Sometimes I tend
to be a bit of a perfectionist. I don't quite have OCD, but I do have CDO which
is similar, but with the letters in alphabetical order like they're supposed to
be.)
I've been using this sample image as a Granite_21 reference point:
https://news.povray.org/povray.binaries.images/attachment/%3C6089814e%40news.povray.org%3E/dakotagrains_sn_test.jpg
This one represents near perfection in my opinion (the color samples I used came
from that picture, by the way). But I agree, both methods produce great results
and I'm more excited than ever regarding Granite_21. Thanks for sharing your
preliminary results!
Kind regards,
Dave Blandston
