POV-Ray : Newsgroups : povray.binaries.images : experiment with image_map : Re: experiment with image_map Server Time
6 Mar 2026 01:39:01 EST (-0500)
Date: 28 Dec 2021 12:40:00
Message: <web.61cb4bbd60f6dbe14cef624e6e066e29@news.povray.org>
If you want the rendered result to look 'sharper' and more like your image_map,
you should not use interpolate at all. But, if you like the blurry look of your
render example, then using interpolate is the proper way to do it.
Do your 3 render examples use 3 *different* methods of interpolation?
