POV-Ray : Newsgroups : povray.binaries.images : Fluorapophyllite-(K) : Re: Fluorapophyllite-(K) Server Time
24 Mar 2026 20:38:16 EDT (-0400)
Date: 9 Nov 2021 19:01:06
Message: <web.618ac5a34f1e127b4cef624e6e066e29@news.povray.org>
> Latest, less inclusions, and slightly more concentrated and de-centered.
> The complete set of files can be found now in the p.b.s-f
> I added a quartz crystal to the set.
I like this. AND the previous render with more bubbles. Beautiful.
BTW, I did not realize that an object with ior could have inclusions (other
objects) with *different* ior's-- I thought such constructs would be an example
of 'variable' ior within an object, which cannot be accomplished in POV-ray,
AFAIU. I had a mistaken notion that the camera ray would 'see' the outer object
surface first, which would then set the ior for the entire union-ed CSG. (Kind
of like the way media operates.) But that's not the case! :-) So I've been
experimenting with this multiple-ior CSG trick, which can produce some visually
interesting results. Thanks for the idea.
