POV-Ray : Newsgroups : povray.binaries.images : Alum : Alum Server Time
18 Mar 2026 02:48:33 EDT (-0400)
  Alum
Date: 19 Sep 2021 19:10:00
Message: <web.6147c32b226a4256cb705ca46e741498@news.povray.org>
Here's an alum crystal.
The face data (including HKL, distance and colors [not used]) were copied from
KrystalShaper and converted to an array-ready format thanks to a couple of find
& replace operations in notepad++. Because the data works with the cubic
crystalline system, they were easily converted into plane normals and offsets.
The planes were then used in an intersection object. 50 faces total. No
light_sources are present in the scene; just reflections.
(If anyone's wondering why I don't simply export POV-Ray files from
KrystalShaper, it's because in the future I intend to have more customization
options for certain faces.)
Here's the source code (minus luminous bloom):
HKL-cubic-alaun.pov
2021 Samuel B.
Suggested command line options:
 +fn +f +a0.3 +am2 +r1
If outputting to luminous bloom:
 +fh +f +a0.3 +am2 +r1
#version 3.7;
global_settings{
 assumed_gamma 1.0
 max_trace_level 11
#default{ finish{ambient 0} }
#declare RGBSun = srgb 1.3*<2, 1.99, 1.97>;
#declare RGBSky = srgb <.45, .475, .5>;
#declare CamPos = <0, 7, -10>;
camera{
 fisheye right x*.7 up y*.7
 location CamPos
 look_at 0
 angle 60/3.5
 aperture .77 focal_point -z blur_samples 30 variance 0
#if(1)
 sky_sphere{
  pigment{
   spherical scale 2 translate z
   poly_wave 2
   rotate -x*30
   rotate y*40
   color_map{
    [0 RGBSky]
    [1 RGBSun]
// ground plane
#if(1)
 plane{
  y, -1.001
  pigment{
   pigment_pattern{
    cylindrical
    scale 5
    translate 2*z
   pigment_map{
    [0 rgb 0]
    [1
     granite
     scale 5
     turbulence .2 lambda 3
     poly_wave .2
  finish{reflection{.2, 1 fresnel metallic 1} conserve_energy}
  normal{granite .05 scale .001}
  interior{ior 1.55}
// KRSCOPY KrystalShaper data copied from program and converted with notepad++
#declare FaceData =
 array[50][7]{
  {1, 0, 0, 1.02, 255, 255, 128},
  {0, 1, 0, 1.02, 255, 255, 128},
  {0, -1, 0, 1.02, 255, 255, 128},
  {-1, 0, 0, 1.02, 255, 255, 128},
  {0, 0, -1, 1.02, 255, 255, 128},
  {0, 0, 1, 1.02, 255, 255, 128},
  {1, 1, 1, 0.7, 0, 255, 255},
  {1, 1, -1, 0.7, 0, 255, 255},
  {1, -1, 1, 0.7, 0, 255, 255},
  {-1, -1, 1, 0.7, 0, 255, 255},
  {-1, 1, 1, 0.7, 0, 255, 255},
  {1, -1, -1, 0.7, 0, 255, 255},
  {-1, -1, -1, 0.7, 0, 255, 255},
  {-1, 1, -1, 0.7, 0, 255, 255},
  {1, 1, 0, 0.799, 255, 128, 128},
  {1, -1, 0, 0.799, 255, 128, 128},
  {-1, -1, 0, 0.799, 255, 128, 128},
  {-1, 1, 0, 0.799, 255, 128, 128},
  {-1, 0, -1, 0.799, 255, 128, 128},
  {0, 1, 1, 0.799, 255, 128, 128},
  {1, 0, -1, 0.799, 255, 128, 128},
  {0, 1, -1, 0.799, 255, 128, 128},
  {1, 0, 1, 0.799, 255, 128, 128},
  {0, -1, -1, 0.799, 255, 128, 128},
  {-1, 0, 1, 0.799, 255, 128, 128},
  {0, -1, 1, 0.799, 255, 128, 128},
  {3, 2, 1, 0.869, 0, 255, 0},
  {-2, -1, -3, 0.869, 0, 255, 0},
  {1, 3, 2, 0.869, 0, 255, 0},
  {-3, -2, -1, 0.869, 0, 255, 0},
  {2, 1, 3, 0.869, 0, 255, 0},
  {-1, -3, -2, 0.869, 0, 255, 0},
  {3, 2, -1, 0.869, 0, 255, 0},
  {-2, -1, 3, 0.869, 0, 255, 0},
  {1, 3, -2, 0.869, 0, 255, 0},
  {-3, -2, 1, 0.869, 0, 255, 0},
  {2, 1, -3, 0.869, 0, 255, 0},
  {-1, -3, 2, 0.869, 0, 255, 0},
  {-1, 3, 2, 0.869, 0, 255, 0},
  {2, -1, 3, 0.869, 0, 255, 0},
  {3, -2, -1, 0.869, 0, 255, 0},
  {-1, 3, -2, 0.869, 0, 255, 0},
  {-2, 1, 3, 0.869, 0, 255, 0},
  {3, -2, 1, 0.869, 0, 255, 0},
  {1, -3, -2, 0.869, 0, 255, 0},
  {-2, 1, -3, 0.869, 0, 255, 0},
  {-3, 2, 1, 0.869, 0, 255, 0},
  {1, -3, 2, 0.869, 0, 255, 0},
  {2, -1, -3, 0.869, 0, 255, 0},
  {-3, 2, -1, 0.869, 0, 255, 0}
// crystal
#if(1)
 intersection{
  #for(I, 0, 49)
   plane{
    <FaceData[I][0], FaceData[I][1], FaceData[I][2]>, FaceData[I][3]
  // I guessed the proper color :/
  pigment{rgb <.85, .7, 1> filter 1}
  finish{reflection{0, 1 fresnel} conserve_energy}
  normal{granite .03 scale .001}
  interior{
   // alum ior from classicgems.net
   ior 1.453
   media{absorption .3}
   // an unrealistic dispersion value
   dispersion 1.075 dispersion_samples 7
  hollow
  rotate -y*43
Download 'hkl-cubic-alaun9m_07s-plus-lb7b1m_02s.jpg' (29 KB)
Preview of image 'hkl-cubic-alaun9m_07s-plus-lb7b1m_02s.jpg'
