POV-Ray : Newsgroups : povray.binaries.images : Luna, Moon... desert satellite : Re: Luna, Moon... desert satellite Server Time
17 Mar 2026 20:19:59 EDT (-0400)
Date: 9 Sep 2021 19:45:00
Message: <web.613a9b76756c3d5acb705ca46e741498@news.povray.org>
> Op 09/09/2021 om 03:24 schreef Samuel B.:
> > Just testing out some moon maps. (...)
> Those maps are getting better over the years... as also the use of them.
> Very nice that little touch of Earth glow in the shadows!
Thank you Thomas. It actually renders very quickly, sans bloom.
Unfortunately, the bump maps appear to be 8-bit grayscale, not 16-bit. Even
though IrfanView reports a 16-bit format, my tests in POV-Ray showed major
terracing artifacts like you would expect from a lower bit depth. (Not seen here
because I kept the resolution below a certain size). I should probably try the
maps them out in other programs to see if POV is at fault, although I doubt it
is...
Sam
