POV-Ray : Newsgroups : povray.binaries.images : Granite_21 - the final macro : Re: Granite_21 - the final macro Server Time
7 Apr 2026 20:55:36 EDT (-0400)
Date: 9 Sep 2021 19:30:00
Message: <web.613a983eb21f010ccb705ca46e741498@news.povray.org>
> The final version of the Granite_21 macro package can be found in
> p.b.scene-files under the same header.
> The image here illustrates, from the start, the principal rule of the
> macro, written on the wall!
Hey, is that a classic Estwing hammer I see? I've got one myself, but it's worn
down. A lot. I probably need to grind it back into shape, but I haven't found
much use for it recently. Estwing used to (and probably still does) have a free
replacement policy, but I never figured it was worth bothering them over.
Not many minerals around here except for granitic rocks, tiny grains of
opalescent quartz, almost-amazonite feldspar and maybe some horneblend. The
latter seems to exhibit some Schillerism when shaped. I think I found some
garnet, too, but it's hard to tell.
What do you plan to use the granite for, if anything?
Sam
