POV-Ray : Newsgroups : povray.binaries.images : Granites Intermezzo : Re: Granites Intermezzo Server Time
24 Mar 2026 07:05:54 EDT (-0400)
Date: 29 Apr 2021 13:25:00
Message: <web.608aeb09cfb077e46adeaecb3f378f2@news.povray.org>
> alright. Getting tired after a day of tweaking.
> Second, overhauled, StepNoise version. Several things learned:
> - to be careful with the /scale/ of the grains. This is as good as I
> dare to go. Larger minerals become increasingly unbelievable, so one
> needs to find the balance (as with the turbulated cells obviously, but
> StepNoise does a much better, although not perfect, job).
> - the mask for the pigment_pattern needs a /very/ careful adjustment.
> The present one is good but could probably be improved further. Good
> enough for now.
> - white grains are present but hardly visible. In the first version they
> were placed at the wrong place within the colour_map, rendering rings
> instead of mineral grains. Corrected that but need now to be enhanced a bit.
> - sslt would probably increase realism, even in the frosted version. I
> am going to look into that.
> Thomas
I am embarrassed to say that I can't see anything from that far. With respect to
that 10cm grid measures, I feel like you are no longer representing the same
rock? Did you work on it like that or with a closer camera? I do feel like
nothing is wrong with what little I see, though ! I have faith in you ! :-)
