POV-Ray : Newsgroups : povray.binaries.images : Had occasion to look at tiling patterns in linear grey. : Re: Had occasion to look at tiling patterns in linear grey. Server Time
27 Mar 2026 21:27:46 EDT (-0400)
Date: 23 Nov 2024 14:16:46
Message: <67422a1e@news.povray.org>
Le 2024-11-22 à 16:07, William F Pokorny a écrit :
> On 11/22/24 08:40, Bald Eagle wrote:
>> William F Pokorny <ano### [at] anonymousorg> wrote:
>>> Some of the tiling pattern's patterns look pretty cool without a color
>>> map - just grey. Attached tiling 21.
>>> Bill P.
>> Nice!
>> Are these the sort of patterns that are provided with POV-Ray - coded
>> by Jerome
>> Grimbert?
> Thanks :-) Though, yes, this is Jerome's work so he deserves the credit.
> Aside: In addition to the 'tiling' pattern (implementing 27 sub-tiling-
> patterns), There is too 'pavement' with a great many possibilities (112
> base arrangements IIRC - plus exterior, interior and form treatments
> thereof). I think it a bit harder to understand and use than is tiling,
> but it's cool too.
>> I'm curious as to what this would look like as a heightfield.
> Attached another grey image on the left that I liked in 'tiling 14'. It
> required the tiny rotation trick to get away from numerical noise.
> Many of the tiling pattern's patterns are not continuous which make
> height fields and isosurfaces difficult / jumpy in direct use. Kenneth
> helps make that point with his recent post. :-)
> On the right isn't a height field, but an isosurface using a new inbuilt
> function in yuqk called f_npmod() which in wrapping the 'tiling 14'
> function implements the pattern modifier (frequency, phase, sine_wave
> etc) code's version of mod() - plus an on the fly scaling. 'tiling 14'
> has 5 tile types so the f_npmod() function call becomes roughly:
>      f_npmod('tiling 14', 1/5, 'value multiplier')
> The function basically makes 'tiling 14' a continuous pattern where all
> 5 tile types have the same 0..? value ranges. An unmodified 'tiling 14'
> function is still used to color / texture the tiles and calk.
> Note. The performance is quite variable where using the 'tiling' pattern
> in isosurfaces. My up front guess is that certain tiling sub-
> patterns(1..27) are much slower than others, but there might well be
> other things in play. I've never dug into what burns the time. The
> isosurface on the right was relatively slow to render.
> Bill P.
When I use a tiling pattern for an isosurface, I use a simple ramp
gradient with a frequency parameter matching the number of domains.
So, for your example, I'd use frequency 5.
Then, use a colourful version of that tiling as pigment.
