POV-Ray : Newsgroups : povray.binaries.images : Reservations : Re: Reservations Server Time
29 Mar 2026 21:39:03 EDT (-0400)
  Re: Reservations
Date: 9 Mar 2024 13:28:22
Message: <65ecaa46$1@news.povray.org>
Il 08/03/2024 14:53, Chris R ha scritto:
> This is an update to the "Interior Brick Scene".  I moved the point of view back
> a bit to see more of the room.  A bunch of the models were updated, including
> the spilled champagne on the table.
> This was about a 2 1/2 day render on my laptop, and does not include any
> radiosity.  I tried doing adding in radiosity earlier and the render rate
> dropped to the under 100 PPM, which means it would take weeks to finish.  There
> are a lot of light sources in the room, so maybe radiosity wouldn't add much to
> the scene anyway.  Also, with the rough surfaces on the brick walls, I find that
> I have to do a lot of tuning to get around radiosity artifacts.
> Anyway, I may do some renders from different points of view, and the letter
> sitting on the napkin ring needs some tweaking so you can tell better what it
> is, but I'm pretty happy over all with the results.
> -- Chris R
The mood is nice, maybe I would put placemats under the dishes.
Paolo
