POV-Ray : Newsgroups : povray.binaries.images : B-DNA : Re: B-DNA - testing the macro Server Time
24 Mar 2026 20:11:31 EDT (-0400)
Date: 10 Feb 2024 03:21:08
Message: <65c731f4$1@news.povray.org>
Op 9-2-2024 om 14:24 schreef Bald Eagle:
> The other thing that might not be immediately obvious, but will help in the
> overall understanding of the macro's general use is that you only need to
> identify 3 points in/on an object in order to line it up with another
> instantiation of itself.
> Anything.  Triangles, cubes, meshes, parametrics, splines, point clouds, or even
> entire included scenes.
Yes, that is the fantastical approach of the macro. And it is so easy in
use!
> Let's say you're modeling something in pieces, and you have a spot on a CSG
> object where you need to place the next piece.  It needs to fit in some specific
> alignment, but it's always easier to model things near the origin, lying flat on
> a plane, etc.
> What you can do is take the points on the csg object that you modeled, and
> concatenate all of the transforms that you used to put the object containing
> that point where it currently is.  Apply that transform to an <x, y, z> vector
> using vtransform, and you have the exact coordinates of those points.
> Now you can take one of those points and place it on the origin, and either with
> math or macros arrange the other two points to lie flat on the plane.  Get those
> 3 coordinates.
> Knowing that the triangle on the plane will now fit perfectly into/onto your csg
> object, you can model your piece, and then use Reorient_Triangle to just move it
> where it needs to go.
> Likely we could use a macro that will just grab that csg triangle and move it to
> the plane at the origin and return the 3 coordinates as a tuple.
I had not yet thought that far, but that would be a logical use of the
macro. Something to experiment with. It might solve some issues I was
struggling with in my LogoPlanet scene recently.
