POV-Ray : Newsgroups : povray.binaries.images : nest plants : Re: nest plants Server Time
25 Mar 2026 00:07:45 EDT (-0400)
  Re: nest plants
Date: 14 Nov 2023 08:23:26
Message: <655374ce$1@news.povray.org>
On 11/14/23 07:08, Mike Miller wrote:
> The tan/yellow areas in the hillside?...that's HDRI BG.
Using exr ?  There is a bug where the HDRI has values which exceed a
half float(a). IIRC. Values end up as HUGE_VAL and you get artifacts
that basically won't go away with normal -ish tweaking.
Bill P.
(a) - POV_Ray's current exr support only works with half float (16 bit)
exr files and many .exr files found today on the internet use the full
32 bit float format and those, sometimes, have values > 16 bits float max.
