POV-Ray : Newsgroups : povray.binaries.images : 6 simple plants : Re: 6 simple plants Server Time
28 Mar 2026 03:32:42 EDT (-0400)
  Re: 6 simple plants
Date: 13 Nov 2023 11:03:54
Message: <655248ea$1@news.povray.org>
Le 2023-11-12 à 09:34, Mike Miller a écrit :
> Alain Martel <kua### [at] videotronca> wrote:
>>>>> 6 plants made from smooth triangle billboards. These render much faster than the
>>>>> clipped sphere approach I was originally using. Scene file posted.
>>>>> Miller
>>>> Those are nice. Make them into mesh to use the instanciation feature of
>>>> the meshes.
>>>> So, instead of :
>>>> #declare ST_leaf =
>>>>       union {
>>>>        //--left 1/2
>>>>        smooth_triangle { p11, n1, p4,  n1, p6,  n1 }
>>>>        smooth_triangle { p11, n1, p10, n1, p4,  n1 }
>>>>        smooth_triangle { p9,  n1, p10, n1, p11, n1 }
>>>>        smooth_triangle { p9,  n1, p8,  n1, p10, n1 }
>>>>        smooth_triangle { p15, n1, p8,  n1, p9,  n1 }
>>>>        smooth_triangle { p15, n1, p14, n1, p8,  n1 }
>>>>        smooth_triangle { p2,  n1, p15, n1, p5,  n1 }
>>>>        smooth_triangle { p2,  n1, p14, n1, p15, n1 }
>>>>        //--right 1/2
>>>>        smooth_triangle { p11, n5, p3,  n5, p12, n5 }
>>>>        smooth_triangle { p11, n5, p6,  n5, p3,  n5 }
>>>>        smooth_triangle { p9,  n5, p12, n5, p7,  n5 }
>>>>        smooth_triangle { p9,  n5, p11, n5, p12, n5 }
>>>>        smooth_triangle { p15, n5, p7,  n5, p13, n5 }
>>>>        smooth_triangle { p15, n5, p9,  n5, p7,  n5 }
>>>>        smooth_triangle { p1,  n5, p15, n5, p13, n5 }
>>>>        smooth_triangle { p1,  n5, p5,  n5, p15, n5 }
>>>> Use this :
>>>> #declare ST_leaf =
>>>>       mesh{
>>>>        //--left 1/2
>>>>        //--right 1/2
>>>> That way, you can place 1000's of copies of the same plant that'll use
>>>> only the storage for a single one.
>>> Alain,
>>> thank you so much! I will definitely fix that. It's been a long time since I
>>> worked with triangles in POV...
>>> I have a new problem ..haha. Now that I've converted these billboards to smooth
>>> triangles, I'm getting a new fog bug showing up in reflections. I'm posting a
>>> snippet of a rendering I did last night using these plants in my nest scene.
>>> Billboards that cross in front the water renders without fog. Strange...may just
>>> give up on using them in this scene. :-)
>>> Mike
>> Triangles do have an interior and an exterior. Try using hollow. It MAY
>> help... Or not.
>> mesh{ ...
>>    hollow
>> Next, you may be faced with the tracing and sampling of that fog. Here,
>> the presence or absence of turbulence is probably not a factor.
>> You may need to use scattering media with the render time taking a
>> serious hit.
>> But, yes. Fog and media tend to not play nice with transparency.
> Just tried your suggestion of using hollow in the mesh statement - It worked!
> Thank you so much...just about to give up. :-)
> Mike.
GREAT !😎🎉
