POV-Ray : Newsgroups : povray.binaries.images : 6 simple plants : Re: 6 simple plants Server Time
7 Apr 2026 02:33:15 EDT (-0400)
  Re: 6 simple plants
Date: 12 Nov 2023 08:51:00
Message: <6550d844$1@news.povray.org>
Le 2023-11-11 à 09:22, Mike Miller a écrit :
> Alain Martel <kua### [at] videotronca> wrote:
>>> 6 plants made from smooth triangle billboards. These render much faster than the
>>> clipped sphere approach I was originally using. Scene file posted.
>>> Miller
>> Those are nice. Make them into mesh to use the instanciation feature of
>> the meshes.
>> So, instead of :
>> #declare ST_leaf =
>>      union {
>>       //--left 1/2
>>       smooth_triangle { p11, n1, p4,  n1, p6,  n1 }
>>       smooth_triangle { p11, n1, p10, n1, p4,  n1 }
>>       smooth_triangle { p9,  n1, p10, n1, p11, n1 }
>>       smooth_triangle { p9,  n1, p8,  n1, p10, n1 }
>>       smooth_triangle { p15, n1, p8,  n1, p9,  n1 }
>>       smooth_triangle { p15, n1, p14, n1, p8,  n1 }
>>       smooth_triangle { p2,  n1, p15, n1, p5,  n1 }
>>       smooth_triangle { p2,  n1, p14, n1, p15, n1 }
>>       //--right 1/2
>>       smooth_triangle { p11, n5, p3,  n5, p12, n5 }
>>       smooth_triangle { p11, n5, p6,  n5, p3,  n5 }
>>       smooth_triangle { p9,  n5, p12, n5, p7,  n5 }
>>       smooth_triangle { p9,  n5, p11, n5, p12, n5 }
>>       smooth_triangle { p15, n5, p7,  n5, p13, n5 }
>>       smooth_triangle { p15, n5, p9,  n5, p7,  n5 }
>>       smooth_triangle { p1,  n5, p15, n5, p13, n5 }
>>       smooth_triangle { p1,  n5, p5,  n5, p15, n5 }
>> Use this :
>> #declare ST_leaf =
>>      mesh{
>>       //--left 1/2
>>       //--right 1/2
>> That way, you can place 1000's of copies of the same plant that'll use
>> only the storage for a single one.
> Alain,
> thank you so much! I will definitely fix that. It's been a long time since I
> worked with triangles in POV...
> I have a new problem ..haha. Now that I've converted these billboards to smooth
> triangles, I'm getting a new fog bug showing up in reflections. I'm posting a
> snippet of a rendering I did last night using these plants in my nest scene.
> Billboards that cross in front the water renders without fog. Strange...may just
> give up on using them in this scene. :-)
> Mike
Triangles do have an interior and an exterior. Try using hollow. It MAY
help... Or not.
mesh{	...
  hollow
Next, you may be faced with the tracing and sampling of that fog. Here,
the presence or absence of turbulence is probably not a factor.
You may need to use scattering media with the render time taking a
serious hit.
But, yes. Fog and media tend to not play nice with transparency.
