POV-Ray : Newsgroups : povray.binaries.images : A povr fork test image for new dens_object pattern. : Re: A povr fork test image for new dens_object pattern. Server Time
28 Mar 2026 09:58:17 EDT (-0400)
Date: 3 Sep 2023 22:21:08
Message: <64f53f14$1@news.povray.org>
On 9/3/23 21:49, William F Pokorny wrote:
> As for using the pattern to perturb raw normals to make things look more
> rounded(a). I'd not thought about it, but I will. I've played quite a
> bit with perturbed normal methods in the povr fork. My guess is
> something based on the surface density measure could work OK for the
> 'far side' edges, but might be problematic where the edge faces the
> incoming rays. There would likely be a visible discontinuity in that
> case. That said, I'll think about it. It's an interesting idea(b).
And on hitting send, I thought, why not just try Sam's idea...
Attached is an image where I turned the pigment plain white - this the
image on the left. I then used the existing dens_object set up as a
normal{} block value pattern. This the image in the middle - the
polarity of the -1..1 function interval is wrong. Well povr has an
'inverse' scalar value pattern wave modifier. Added it and we get the
image on the right - and, dang Sam, that looks pretty good as a quick go
at it! :-) Thanks for the idea!
Bill P.
Download 'samsnormalidea.jpg' (27 KB)
Preview of image 'samsnormalidea.jpg'
