POV-Ray : Newsgroups : povray.binaries.images : Playing with the mesh camera : Re: Playing with the mesh camera Server Time
26 Mar 2026 00:59:22 EDT (-0400)
Date: 20 May 2023 00:18:31
Message: <64684a17$1@news.povray.org>
On 5/19/2023 5:21 PM, Kenneth wrote:
> SO... I've been concentrating on the 'meshcam_persp.demo' scene, and came up
> with a way to easily generate a two-'camera' stereo view, at least as the
> *basics* of a 3D anaglyph. It's the same set-up as the motion-blur code, but
> using  only two 'eyes'. The camera's initial position doesn't actually change;
> it's the camera's mesh that is displaced, which has the same effect. Honestly,
> I was not *sure* that this trick produced a true 3-D effect, so I had to prove
> it to myself with a different test set-up.
> (It would seem that the 'meshcam_stereo_demo' scene would be the logical choice
> for my experiments, but I have not yet been able to *overlap* the two images
> there instead of being side-by-side. My math attempts have been woefully crude
> and unsuccessful.)
I think that demo is designed for things like Google Cardboard.
> So far, my attempts to color each of the two views as red/cyan, *within* the
> meshcam scene, have all failed. I've tried using the instantiated meshes as
> objects...or semi-transparent spheres... or even tiny thin cylinders and discs--
> but they interfere with each other in an odd way when used in pairs, and ruin
> the effect. For a *single* camera view (only one mesh), an instantiated/colored
> mesh works very well-- but not with two views that overlap. As you alluded to,
> the mesh-as-CAMERA and the mesh-as-INSTANTIATED-into-the-scene behave completely
> differently. That's difficult to visualize and explain though.
Oddly enough, you can give the mesh a pigment:
   mesh_camera { 2 0
     mesh { spherical_mesh pigment { blue 1 transmit 0.1 }
       transform { Position_on_Camera(Camera_Location, Camera_Look_At,
Camera_Sky) }
     mesh { perspective_mesh pigment { red 1 transmit 0.1 }
and the thing renders without color. I would expect this to raise a
parsing error but it just ignores it. It's a shame, because this could
really help with these sorts of effects.
> Here are some interesting little facts that I've learned along the way:
> 1) The camera mesh is curved-- like a section of a sphere surface-- and is not
> actually at the given 'c_location'; that's the CENTER of the 'sphere'. And the
> spherical diameter depends on the given 'c_angle'.
Yes. It's a proper pinhole, not like the standard perspective camera.
> 2) When the camera-mesh is first constructed in 'meshcam_macros.inc', it is
> apparently made facing +z, and centered on the origin (that is, the 'center of
> the sphere' is at the origin, I think). Then it's later re-positioned and
> re-oriented by the meshcam_placement macro-- like this in the
> 'meshcam_persp_demo' file:
>                    camera{
>                            mesh_camera{ aa_samples+1    0
>                            mesh{camera_mesh
>                            meshcam_placement(c_location,c_look_at)
> So, prior to meshcam_placement, the mesh can be moved around (translated) in an
> understandable x,y,z way, if you choose to :-)
Fun, ain't it? This is the easiest way to do it, in my opinion. There's
less math. At least, there's easier ways to sequester the math in a macro.
> More to come (!)
I'm looking forward to it. You're faster than I am.
Josh
