POV-Ray : Newsgroups : povray.binaries.images : A quick povr branch micro normal image. : Re: A quick povr branch micro normal image. Server Time
26 Mar 2026 08:47:13 EDT (-0400)
Date: 24 Mar 2023 21:46:46
Message: <641e5286$1@news.povray.org>
On 3/24/23 11:39, William F Pokorny wrote:
> At the moment I am trying to get your seg fault signature above using a
> debug compile having symbols - where the core file generated should be
> useful.
> You didn't get this fail every time, and so far I've not gotten a
> segfault. I'm just running it and running it again for a while with
> verbose false and logging enabled. We'll see.
No segfaults of the differing type you saw.
I did get two different Parse Error signatures early. One for an array
subscript out of range and another via the include of parse_fore.tmp
attempting to access an uninitialized array element. Neither made sense
to me.
Then the blasted povr code proceeded to run cleanly both partial runs
and full ones for 6 passes.
I went back to the original failing set up starting at frame 3000 with
both verbose and log frames on - which had been failing at the same
'spots' for me - and at least the most recent pass decided other spots /
cylinders should now fail.
Only thing that's clear is what was clear before - we have no problems
until the frame counts are 2500, 3000 or more.
Anyhow. Answering the question you asked a year ago. I don't see the
segfaults you saw with verbose off and logging on. Mostly things worked
in this configuration...
Future posts on this povr only problem, I'll put in a new thread
somewhere. Probably user.patches. This thread got really long and became
'twelve ways' unrelated to the original topic!
Bill P.
