POV-Ray : Newsgroups : povray.binaries.images : Oscilloscope : Re: Oscilloscope Server Time
8 Apr 2026 03:35:29 EDT (-0400)
  Re: Oscilloscope
Date: 6 Feb 2023 02:41:45
Message: <63e0af39@news.povray.org>
This helped, the blotchiness is acceptable for a still image but still
jumpy in animation.
Raising the 'scope - yes, good point.
On 06/02/2023 2:14 AM, Alain Martel wrote:
> Le 2023-02-05 à 05:42, m@b a écrit :
> You need to increase the sample value.
> Using the two values version may help.
> Have the pretrace go deeper.
> As for the count, use the two values version for nearest_count.
> Try this version :
> global_settings {
>   assumed_gamma 1
>   #if (Radiosity)
>    radiosity {
>     pretrace_start 0.04
>     pretrace_end 0.0025 // or even 0.00125
> Content-Type: multipart/mixed;
> boundary="------------0rgDYJuCNp1Z4Md0WnOykdJ3"
> Date: Sun, 5 Feb 2023 18:42:09 +0800
> MIME-Version: 1.0
> User-Agent: Mozilla/5.0 (Windows NT 10.0; Win64; x64; rv:102.0)
> Gecko/20100101
> Thunderbird/102.6.1
> Subject: Re: Oscilloscope
> Content-Language: en-US
> Newsgroups: povray.binaries.images
> References: <63de46eb@news.povray.org>
> <web.63de754733e903b1f9dae3025979125@news.povray.org>
> From: "m@b" <sai### [at] googlemailcom>
> In-Reply-To: <web.63de754733e903b1f9dae3025979125@news.povray.org>
> NNTP-Posting-Host: 122.2.111.112
> Message-ID: <63df880b@news.povray.org>
> X-Trace: news.povray.org 1675593739 122.2.111.112 (5 Feb 2023 05:42:19
> -0500)
> Lines: 15631
> X-No-Archive: Yes
> X-Copyright: This copyrighted article comes from a private news server
> and may NOT be distributed on USENET or other news servers.
> X-POV-Header: --- --- --- --- --- --- --- --- --- --- --- ---
> Path: news.povray.org!not-for-mail
> Xref: news.povray.org povray.binaries.images:146685
> This is a multi-part message in MIME format.
> --------------0rgDYJuCNp1Z4Md0WnOykdJ3
> Content-Type: text/plain; charset=UTF-8; format=flowed
> Content-Transfer-Encoding: 7bit
> On 04/02/2023 11:09 PM, Bald Eagle wrote:
>> Nice!
>> Try it with radiosity and using the background image as an hdr light
>> source:
>> global_settings {
>>   assumed_gamma 1
>>   #if (Radiosity)
>>    radiosity {
>>     pretrace_start 0.04
>>     pretrace_end 0.01
>>     count 200
>>     recursion_limit 3
>>     nearest_count 10
>>     error_bound 0.5
>>   #end
>> #declare Environment =
>> sphere {
>>   0, 1
>>   hollow on
>>   material {
>>    texture { uv_mapping
>>     pigment {
>>      image_map {
>>       hdr "FILENAME.hdr"
>>       gamma 1.5
>>       map_type 0
>>       interpolate 2
>>       once
>>    finish {emission 1}
>>   interior { ior 1.0 }
>>   no_shadow
>> object { Environment scale 1000} // might have to adjust  ;)
> Thanks for that. I am getting a patchy illumination, when I animate it
> there is inconsistency between frames. Any thoughts?
> The only change I made was to reduce the Environment gamma to 1, the
> scene was over-illuminated at 1.5.
> m@
> Content-Type: image/png; name="CRO 01.png"
> Content-Disposition: attachment; filename="CRO 01.png"
> Content-Transfer-Encoding: base64
> iVBORw0KGgoAAAANSUhEUgAAA1YAAAHgCAIAAAApMmt9AAAABGdBTUEAALGPC/xhBQAAAANz
> QklUCAgI2+FP4AAAAAd0SU1FB+cCBQonGTmyvbsAAAAedEVYdFNvZnR3YXJlAFBPVi1SYXkg
> djMuOC4wLWJldGEuMeAriKEAAABXdEVYdENvbW1lbnQAUmVuZGVyIERhdGU6IDIwMjMtMDIt
> MDUgMTA6Mzk6MjVaClBsYXRmb3JtOiBpNjg2LXBjLXdpbi1zc2UyCkNvbXBpbGVyOiBtc3Zj
> IDE0ClqZthsAACAASURBVHic7L1Lr23bcR72VdWYa+/zuk9e8vJNiTIpxZTlJHYsCVaCJAJs
> A0ksIG5YQFppBPlX6aWdAIHhjhUYMBTFii1ZpiVcipJFUnxe3se555y915pzVJUbVTXGWOdK
> gNVgoIYWL/fZe6015xyPenz1HPSP/tf/DnCYAyAgfzoAYiICxYuJmYiJiZjjVyI4HESA5wvu
> 7oC7uQNwc4fD6wsA8oe7mYMov+oez447IH6NSz3/8HGlu7sTMC6sS8jdchL1XeS9AMy7Ony+
> Fc8B4HC38UAiGk/EuDoHMK9EjtHN6mtEpm6qbkZELMxEQCwYAUQUw6th5l3hbsub46vxBtXN
> EctOuQHLvBzMFNcxMxGZqbsTCzPPG6N2FBT3HXePzY67mbubE+etxvrHFMzM3c0sro5Pzd3M
> 3HILYotzCc1NzcxVrWs3Nbe4B5JqQICbKUjb1l5/61Nvf/7zW9u20ybbdjnv9y/uP/jRu8/e
> f79rByHoETVaV8sRuMHV4W4+hgEAxLWslEQVWyMUaxN7kEtKRiDUrJnYQYMsAfTDTI3g3JhF
>   // more pretrace sampling almost always reduce noise and artefacts.
>     count 350 999 // Should reduce those dark splotches.
>   // Second value set a sampling direction pool.
>   // Second value MUST be greater than the first
>     recursion_limit 2 // 1 may even be enough.
>     nearest_count 20 5 // enable adaptive sampling and pretrace
>   // second value must be the smaller one.
>   // Larger first value often help to reduce the dark splotches,
>   // and also make then less sharp.
>     error_bound 0.35
>   #end
> Try raising the oscilloscope a little bit above the table. After all,
> most have rubber pads under them acting as short legs.
