POV-Ray : Newsgroups : povray.binaries.images : Oscilloscope : Re: Oscilloscope Server Time
30 Mar 2026 03:30:05 EDT (-0400)
  Re: Oscilloscope
Date: 6 Feb 2023 02:37:31
Message: <63e0ae3b@news.povray.org>
On 06/02/2023 5:41 AM, William F Pokorny wrote:
> On 2/5/23 05:42, m@b wrote:
>>>    texture { uv_mapping
>>>     pigment {
>>>      image_map {
>>>       hdr "FILENAME.hdr"
>>>       gamma 1.5
>>>       map_type 0
>>>       interpolate 2
>>>       once
>>>    finish {emission 1}
>>>   interior { ior 1.0 }
>>>   no_shadow
>>> object { Environment scale 1000} // might have to adjust  😉
>> Thanks for that. I am getting a patchy illumination, when I animate it
>> there is inconsistency between frames. Any thoughts?
>> The only change I made was to reduce the Environment gamma to 1, the
>> scene was over-illuminated at 1.5.
> Bill W. - Is there a reason for using uv_mapping with map_type 0 over
> map_type 1 only in the image_map block? I think what you have OK, but
> it's not how I would have coded the mapping. :-)
> Random thoughts / questions.
> - With .exr and .hdr images the file gamma should always be left at 1.0.
> These files have values in both the [0,1) range and [1,1+]. This means
> any gamma other than 1.0 creates adjustments which move in opposite
> directions depending upon whether particular color channel values at a
> given pixel <1 or >=1. It 'should be' any .hdr, .exr file one finds out
> and about was written at a gamma of 1.0. IIRC, POV-Ray itself cannot
> write .hdr / .exr files at other than 1.0.
Yes - Already discovered :-)
> - With .exr and .hdr images, interpolation is I believe iffy. The image
> interpolation code was written for [0,1] ranges. I usually use no
> interpolation with high dynamic range images and move to higher
> resolution environment maps if need be. However, I've not 'really'
> looked at how the different interpolation options work with typical .exr
> and .hdr images.
Interpolation turned off – no change in timing, no improvement observed.
I turned it back on again!
> - With respect to blotchiness frame to frame, remember, v3.7 introduced
> the radiosity high reproducibility option. Use High_Reproducibility /
> +HR on the command line or in the ini file. An more reliable alternative
> is to use single threads for each frame (+wt1). This, though, might lead
> one to manually break up the rendering of frames into buckets to make
> use of all your cores / threads.
High_Reproducibility increased the frame time from 0:53 to 3:30.
The exhibit below has High_Reproducibility on for the first half then
off. Some improvement.
> - Puzzling to me - some of the dark grid lines on the screen flicker in
> and out of existence during the render...? Unsure why this would happen
> unless perhaps using method 3 anti aliasing? If using method 3 remember
> you need to specify the seed used (can't recall the ini/command line
> option +ss maybe?) to keep results consistent render to render.
> Bill P.
Changed to anti aliasing method 1 – no visible difference. This problem
goes away when I do a final render at higher resolution.
m@
Download 'high_reproducibility=on then off.mp4.dat' (176 KB)
