POV-Ray : Newsgroups : povray.binaries.images : Glass for v3.8 finish features : Re: Glass for v3.8 finish features Server Time
5 Apr 2026 13:23:57 EDT (-0400)
Date: 11 Aug 2022 11:25:34
Message: <62f51f6e@news.povray.org>
Op 10-8-2022 om 17:42 schreef Alain Martel:
> The HDR map never emit photons.
> What you can do to get caustics from an HDR map is to use radiosity. As
> the surface receiving the caustics is close to the objects causing it,
> your radiosity settings can still be lenient. You only a small
> error_bound value.
> Try this as a starter :
> global_settings{ assumed_gamma 1
>      radiosity{
>          error_bound 0.1 // may try smaller
>          count 150 1111
>          low_error_factor 0.2
>          pretrace_end 0.005
Excellent suggestion, concentrating on the caustics! Thanks Alain. This
is the result with:
error_bound      0.01
low_error_factor 0.1
pretrace_start  8/max(image_width,image_height)
pretrace_end    1/max(image_width,image_height)
and stochastic render:
+am3 +a0.01 +ac0.90 +r3
render time was only about 10 minutes.
Download 'glass_test_04.png' (554 KB)
Preview of image 'glass_test_04.png'
