POV-Ray : Newsgroups : povray.binaries.images : Glass for v3.8 finish features : Re: Glass for v3.8 finish features Server Time
31 Mar 2026 08:13:27 EDT (-0400)
Date: 9 Aug 2022 13:09:22
Message: <62f294c2$1@news.povray.org>
Am 09.08.2022 um 17:16 schrieb William F Pokorny:
> On 8/9/22 10:50, Thomas de Groot wrote:
>> Op 9-8-2022 om 14:53 schreef Thomas de Groot:
>>> initially, I wanted to concentrate on the hdr light sources though...
>> ...and when I do, no photons are generated!
>> I use
>>    photons {
>>      refraction on
>>      reflection on
>> for the sphere with the hdr map, identical to the code for the light
>> source. Decreasing spacing down to a ridiculously small value doesn't
>> change anything. I must be missing something here...
> I'm perhaps not following, but...
> Taking your hdr sphere to be an actual hollow sphere, you are making it
> a photon target for any photon light sources by adding the photon block
> above. In other words - as far as I know - there is no way to shoot
> photons from other than a traditional light sources.
> Aside: I've never tried to shoot photons from a light source inside a
> hollow object at the inside surface of that object. I'm not sure it
> would work given the how the radial 'shooting pattern' is aimed at
> target objects. Perhaps this the reason why you get no photons? Hmm,
> maybe a spot light would work... Too long since I've played with photons.
> Bill P.
Unfortunatelly, Bill seems to be right. I tried a bit, but it seems to
be impossible to persuade a HDRI light to cast photons, so we need POV
4.0 ;)
Best regards,
Michael
