POV-Ray : Newsgroups : povray.binaries.images : trace() is unreliable on lathe : Re: trace() is unreliable on lathe Server Time
24 Mar 2026 00:49:56 EDT (-0400)
Date: 27 Apr 2022 17:56:41
Message: <6269bc19$1@news.povray.org>
On 2022-04-27 13:31 9-40, Kenneth wrote:
> As a more general question, is it necessary to trace the objects strictly along
> the x/y/z axes? In other words, would a random (OR ordered) series of trace
> operations-- originating from a 'sphere' outside the object and all directed
> toward <0,0,0> -- suit your purpose instead?
I propose to use numerical integration, which requires slices
perpendicular to the y axis.
> Although, I suppose any indents in
> the shapes would present a problem with that scheme.
I intend to restrict the domain to objects that can be described with a
function in y; that is, with the same restrictions as the sor primitive.
 (Which means the last 4 objects in each image would be rejected as
valid inputs.)
