POV-Ray : Newsgroups : povray.binaries.images : Behavior of bounded_by : Re: Behavior of bounded_by Server Time
24 Mar 2026 09:15:22 EDT (-0400)
Date: 18 Apr 2022 11:07:16
Message: <625d7ea4$1@news.povray.org>
Le 2022-04-18 à 07:01, m@b a écrit :
> HI,
> I made this leaf spring using segments of a rounded tube.
> It looks fine when viewed straight-on but assumes a funny angle at the
> ends when viewed from the side.
> What is going on?
You are incorrectly using bounded_by as an alternative for an intersection.
ANY ray that hit the bounded_by shape will cause the bounded_by object
to be evaluated, even if that part is actually outside the bounded_by
object. Even if that part is in front of the bounded_by shape.
Instead, you should use an intersection or add clipped_by{bounded_by}
The first will close the object. You see the surface of the intersecting
object.
The second will leave the ends open. Adding an interior_texture will
make it obvious.
