POV-Ray : Newsgroups : povray.binaries.images : New Characters for Master of Puppets Font : Re: New Characters for Master of Puppets Font Server Time
29 Mar 2026 21:40:35 EDT (-0400)
Date: 9 Apr 2022 13:40:28
Message: <6251c50c$1@news.povray.org>
On 4/9/22 00:10, jr wrote:
> William F Pokorny<ano### [at] anonymousorg>  wrote:
>> Took me a while, but I now see it. I have to set
>> #declare MOP_UseFrenchQuoteMarks = yes;
>> in quote.pov as setting it to no works OK for me.
> yes, same here.  and suspect you're right about it being .. entangled with the
> macro caching mechanism (that macro is large, 118K+ over (close to) 3100 lines.
I think I now understand the cause of the seek errors, though not yet
all the gritty code details.
In v3.8, work was done in the parser to recognize fixed conditional
states and to skip (not parse) inactive blocks and store
pre-seek-indexes into the file(s) defining macros.
In jr's code he has:
#include "masterofpuppetsfont_Apr07_2022.inc"
#declare MOP_Gap                 = .14;
#declare MOP_Space               = .65;
#declare MOP_FontRadius          = .0625;
However, given Dave added:
#ifndef (MOP_UseFrenchQuoteMarks)
     #declare MOP_UseFrenchQuoteMarks = no;
to the bottom of the include, the macros in the include are parsed and
'seek indexes' are set up into the run time include file(s) as if
MOP_UseFrenchQuoteMarks is a fixed 'no'.
Changing jr's code to:
such that the include comes after the declare works.
The deeper tangle here is there is a general implication for v3.8 onward
for macros and includes.
If some global value setting - ones not passed to a macro, but evaluated
as a global when the macro/include is first read - can effectively
change the size of the macro (the stored macro 'file') due the parsing
skip optimizations, we should force the definition << before >> the
include is first parsed.
Or! Pass the conditional value to the macro(a) to avoid optimizations.
In other words use a passed parameter value over the globally declared
setting.
I believe Dave's font include file needs at a minimum to have the
defaulting changed to:
     #if (version >= 3.8)
         #error "MOP_UseFrenchQuoteMarks must be pre-declared yes or no."
     #else
Further, checking in 3.8 onward that the definition is truly in the
global namespace a good idea too, but it's not shown.
Strictly, even value settings could change the stored macro file(s) if
there are related conditionals. It's not too likely in practice.
(a) - I've not yet tried passing the setting to the macro to see if it
fixes the problem as expected...
Not sure there is any general source code fix here beyond rolling back
all the v3.8 parser optimizations which 'might' cause problems.
If I get time to do some confirmation of more detailed-cause, it might
be we could detect and warn/error on conditional optimization which
depend upon global definitions. In other words, force such conditional
values to be passed on the macro call, but such a 'fix', would sometimes
complain about otherwise valid code.
I'll let this issue bang around in my skull for a while I guess.
Bill P.
Aside for those wondering:
Why do <v3.8 version work with jr's original code?
I believe it's because the entire file in which the macro is defined is
read again on each reference to the macro therein. This is slow,
especially if a using a spinning physical disk drive(b).
(b) - These days, with solid state drives and heavy memory caching of
files both ivia the OS and disk hardware, I expect the re-read of the
defining file on every call much less noticeable as a penalty.
